1. PsychDoc's Avatar
    http://www.amazon.com/Samsung-Class-...cUvbUpU5036983
    Samsung 64GB EVO Class 10 Micro SDXC Card with Adapter up to 48/MB/s (MB-MP64DA/AM) for $17.95.
    03-06-2016 12:53 PM
  2. KimJongOMG's Avatar
    I'd step up to at least an Evo+ card from Samsung but at those prices, you might as well step up again to the Pro.
    You want to stick with at least U-3 card to really future proof your phone until the next round of phones come along next year.
    03-06-2016 01:03 PM
  3. brava27's Avatar
    Are they not all the same?
    03-06-2016 01:48 PM
  4. KimJongOMG's Avatar
    The read speeds can be similar but it's the write speeds that really matter if you're taking pictures and recording video directly to the SD card like most folks will be doing.
    Evo - Read 23 MB/s | Write 16 MB/s
    Evo+ - Read 82 MB/s | Write 26 MB/s
    Pro - Read 91 MB/s | Write 79 MB/s
    Pro+ - Read 92 MB/s | Write 86 MB/s
    Faster the better for moving large files quickly.
    vamsiguduru likes this.
    03-06-2016 02:12 PM
  5. getdez's Avatar
    do the specs really translate into a noticeable real world difference when taking pics
    03-06-2016 02:30 PM
  6. KimJongOMG's Avatar
    Just single shot pictures? No. 4K video and extended burst shots, absolutely. I also don't like it when it takes a long time to transfer files from my computer to my phone.
    03-06-2016 02:33 PM
  7. TMavC5's Avatar
    You plan recording 4k for long period of time?
    03-06-2016 02:34 PM
  8. getdez's Avatar
    no - and i really don't transfer files back and forth between comp/phone. Burst photos - sometimes but not a lot of 4k videos or file xfers..
    03-06-2016 02:39 PM
  9. KimJongOMG's Avatar
    You're fine with a class 10 in that case. I would go with the biggest capacity class 10 your budget allows.
    getdez likes this.
    03-06-2016 03:03 PM
  10. PsychDoc's Avatar
    Ok, I ended up ordering the Samsung Pro Plus, 32GB which is labeled SDHC. Should that be good? Is there a SDXC version? Would it be any better?
    03-06-2016 03:04 PM
  11. t11rmh's Avatar
    SDXC IS a sizing naming convention for cards bigger than 32GB. So you can't have a 32GB SDXC card.
    Posted from my kicking Samsung Note4 on Lollipop 5.1.1
    PsychDoc likes this.
    03-06-2016 03:28 PM
  12. TMavC5's Avatar
    Then a nice class 10 UHI I will be just fine.
    getdez likes this.
    03-06-2016 03:32 PM
  13. KimJongOMG's Avatar
    You can get double the capacity for a slight decrease in speed, for the same price, if you go with the 64GB Pro instead of the 32 GB Pro Plus.
    03-06-2016 03:41 PM
  14. PsychDoc's Avatar
    Yeah I know but I think doubling the storage available on the phone's internal storage will be way more than enough.
    03-06-2016 03:58 PM
  15. KimJongOMG's Avatar
    In that case, you're good to go for anything you can throw at your phone! Rocks excluded.
    03-06-2016 04:04 PM
  16. SW1990WBA's Avatar
    Have no idea which card to order myself, never had a phone before thats used them due to mainly being Apple. I was going to order a SanDisk Ultra 128GB - can't link it just yet due to not being at 10 posts - a quick amazon search though and it's easy to locate
    Heard of some issues with SanDisk and Samsung though
    03-06-2016 07:03 PM
  17. xocomaox's Avatar
    Unless you are going to enable Adaptable Storage on your phone (you can do this on the S7 despite what Samsung said about not having it), there's no need to worry about the speed of the card for 4k and pics. You should be saving that to your phone internal memory! Move the files over to the SD card after you take them every so often... Problem solved.
    Laura Knotek likes this.
    03-06-2016 08:04 PM
  1. How can I tell if Doze is working on my Samsung Galaxy S7 Edge?
    By janderson1271 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 07:21 AM
  2. Replies: 1
    Last Post: 03-08-2016, 01:50 AM
  3. Looking for a thread on rooting an Sprint HTC One M8?
    By AC Question in forum HTC One M8 Rooting, ROMs, & Hacks
    Last Post: 03-08-2016, 01:45 AM
  4. How do I save my photos to my sd card?
    By AC Question in forum Moto G (2013)
    Last Post: 03-07-2016, 06:06 PM
