1. TechGod2014's Avatar
    Very simple question. The title says it all.
    I know its way too early, but I already know of a few that made this jump.
    Are u able to live without the S pen?
    Is the difference noticeable?
    Is your Note 5 a very expensive paper weight now?
    Or are u already thinking of returning the S7E and holding out for the Note 6?
    03-06-2016 08:50 PM
  2. ThrottleJohnny's Avatar
    I had a Note 5 and just went to the S7E. If you are addicted to the spen, do not upgrade because you will miss it.
    Otherwise, I think it depends on what you want that the Note 5 doesn't already offer. For me, I wanted the bigger battery, low light camera and spiffy look. I was always envious of my wife's Edge+. So far I ready love this phone. Performance wise, there isn't a huge difference imo.
    However I do have a backup as I kept my Note as well.
    TechGod2014 likes this.
    03-06-2016 09:10 PM
  3. dpham00's Avatar
    I don't have my s7 edge yet, but I don't use the s pen much so it wouldn't really matter too much. With that said, I don't expect it to be faster, I got the s7 edge for the better camera and ip68.
    03-06-2016 10:45 PM
  4. terrain's Avatar
    Worth it - of course. Note and Edge are totally different designs/concepts. I used my PEN all the time on Note 2,3,4 - not much at all on 5 so I dont plan to miss it on the edge. If Note 6 is a 6 inch with pen/edge option I may go back to Note instead of iphone 7.
    03-06-2016 11:16 PM
  5. anon(5719825)'s Avatar
    I'm using both for now. My S7 Edge will be my main phone and I'll mostly just use the Note 5 at home. I get more then double the battery life on my S7 Edge. I can barely get 2 hrs screen time on my Note 5.
    03-07-2016 12:55 AM
  6. brava27's Avatar
    You didn't answer the op question. Is it worth it to upgrade? Not all of us can afford to keep both phones.
    03-07-2016 01:03 AM
  7. anon(5719825)'s Avatar
    I think I answered it. The battery life alone makes it worth it.
    03-07-2016 01:11 AM
  8. TechGod2014's Avatar
    Wow. Only 2 hours of SOT? That's terrible. That's worse than my S6.
    03-07-2016 01:31 AM
  9. anon(5719825)'s Avatar
    Yeah, I'm not happy with it. 14hrs standby with 57 minutes screen time and 43% battery.
    I got 5 hrs screen time earlier today on a full charge on my S7 Edge with 1 day 4 hrs standby. This phone is worth every cent I paid for it.
    03-07-2016 01:53 AM
  10. robertopod1968's Avatar
    5 hours sot over 20 hours with my note 5 religiously, without fail everyday. Looking forward to 20 hours with 7 sot on the S7 Edge.
    03-07-2016 02:11 AM
  11. anon(5719825)'s Avatar
    I've just reset my Note 5 to factory once again and I'm just going to a install apps very slowly until I find out what is using my battery life. I have no idea what it could be because I have all the same things running on my S7 Edge.
    03-07-2016 02:18 AM
  12. TechGod2014's Avatar
    Do the note 5's have android M?
    03-07-2016 05:56 AM
  13. anon(5719825)'s Avatar
    Verizon has it but not T-Mobile which is who my phones carrier is.
    03-07-2016 06:15 AM
  14. TechGod2014's Avatar
    Wow. How could the Note not have that update already? Crazy. I'm sure once it does get it it will run a lil more efficient.
    03-07-2016 02:57 PM
  15. Adranalyne's Avatar
    I won't have the S7 Edge until tomorrow and am currently using the Note 5, but I've had some hands-on time with it and I'd say it's worth the upgrade. Now I don't use the S Pen a lot so that probably has a lot to do with it, but the Edge checks off a few boxes the Note doesn't (or doesn't as much). There's a 600 mah larger battery in a smaller device, it's more durable, has microSD support, and looks to have improved the low light performance/speed of the camera by quite a bit. For me, that's enough to warrant a switch, but I'd completely understand if someone wanted to keep the Note 5 and wait. To me, that says more about how awesome the Note 5 still is than anything else.
    03-07-2016 03:14 PM
  1. Who owns the intellectual property stored in the cloud
    By cliffwa8 in forum Nextbit Robin
    Last Post: 03-17-2016, 12:26 AM
  2. I'd like to see user manual for ASUS Zenphone 2
    Last Post: 03-06-2016, 11:33 PM
  3. Replies: 0
    Last Post: 03-06-2016, 08:31 PM
  4. galaxy note 3 doesn't show pictures on sd card
    Last Post: 03-06-2016, 08:07 PM
  5. Replies: 0
    Last Post: 03-06-2016, 07:52 PM
