1. chefmorry's Avatar
    Question. I love having the edge panels. I use it often for both apps and people.
    I also use a third party alarm clock app.... Alarm Clock Plus. I'm used to having it in bed side mode while I sleep.
    With the edge panel, though, the gray tab is always visible on the side of the screen. Do I have to worry about it burning into the screen over the course of time? It's on all night.... Every night. Can't imagine that being very good for the screen. The time is dimmed and always moving, to prevent it from burning into the screen, but I can see the little grey tab causing an issue with the screen.
    03-06-2016 10:56 PM
  2. dpham00's Avatar
    I would certainly be worried about burn in if it is on the whole night every night. But I am assuming that the brightness is low so it probably wouldn't be too bad. Still, I would consider another option that didn't have it, if possible
    03-07-2016 02:38 PM
  3. KimJongOMG's Avatar
    I would get rid of that tab to be on the safe side.
    03-07-2016 03:04 PM
  1. How can I tell if Doze is working on my Samsung Galaxy S7 Edge?
    By janderson1271 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 07:21 AM
  2. Replies: 1
    Last Post: 03-08-2016, 01:49 AM
  3. Replies: 1
    Last Post: 03-07-2016, 06:10 PM
  4. Galaxy S5 email problem, can I get some help?
    By Alexphilly69 in forum Samsung Galaxy S5
    Last Post: 03-07-2016, 05:21 PM
