1. janderson1271's Avatar
    I've seen a few tidbits here and there from people that have the phone already. I'm picking mine up at 10 am and would appreciate any help to get my phone through the day. Are there any things that can/should be turned off that can be battery hogs? Any worthless settings to switch off or change? Thanks!
    03-07-2016 12:02 AM
  2. Redraider001's Avatar
    I am getting an average of 6 to 7 hrs screen on time plus if using only video a projected 9 to 10 hrs SOT.. thats amazing.
    I can easily go about 2-3 days on this phone.
    * Turn off all unwanted stuff including pre-installed once using apps manager
    * Turn off notification for all apps except stuff that I deem I need
    * black background, dark material theme
    * In developer options, turn off all animations
    * location off
    * No google now .. i really dont use it much
    * Manual brightness control
    * Turn off sync.
    * No always on display. I have colored notifications and thats more than enough. I do use edge feed when screen is off though
    03-07-2016 11:43 AM
  3. janderson1271's Avatar
    Thank you for this!
    I did most of the things on this list. I was unable to find the animations in the developer options although I did get into the developer options.
    If anybody knows any more things to try please post them here!
    03-07-2016 05:33 PM
  4. Eric R's Avatar
    Thank you for this!
    Attached Thumbnails Tips & Tricks: Battery Optimization - Galaxy s7 Edge?-2986.jpg
    03-07-2016 05:59 PM
  5. vr002sh's Avatar
    you have to scroll down a bit, further down than I remember on previous phones.
    03-07-2016 07:21 PM
  6. Jmblack6307's Avatar
    How do you get emails with sync off? How much do you drain overnight?
    06-09-2016 06:47 PM
  7. chanchan05's Avatar
    You could always retrieve them manually. Although of course this is dependent on how often you receive important emails. If it's not too often for you and not too critical, then you can get away with this. Or even set it to sync every 4 or 12hrs.
    06-09-2016 07:12 PM
  8. love4speechless's Avatar
    Where is the options for changing to manual email or syncing less often?
    06-09-2016 08:05 PM
  9. chanchan05's Avatar
    Depends on the email app. If you use the built in one, just open it>more>tap on the account you want to change>sync schedule.
    love4speechless likes this.
    06-09-2016 08:29 PM
  1. battery issues
    By wascar G in forum Samsung Galaxy Note 4
    Last Post: 03-07-2016, 03:07 PM
  2. Samsung Galaxy S7 Edge Edge panels and burn in
    By chefmorry in forum Samsung Galaxy S7 edge
    Last Post: 03-07-2016, 03:04 PM
  3. Does cached data affect the battery life?
    By AC Question in forum Sony Xperia Z3
    Last Post: 03-07-2016, 04:44 AM
  4. Samsung galaxy s7 unblock
    By Harinder Singh4 in forum Samsung Galaxy S7
    Last Post: 03-06-2016, 10:48 PM
  5. Samsung Galaxy A5 stolen
    By Harinder Singh4 in forum Samsung Galaxy A5
    Last Post: 03-06-2016, 10:47 PM
