11-19-2016 06:23 AM
27 12
tools
  1. keri2000's Avatar
    Coming from the iPhone. Does the S7 have visual voicemail provided by Samsung like Apple does for the iPhone or is this something I'll need to pay Verizon for?
    03-07-2016 10:16 AM
  2. KimJongOMG's Avatar
    I've never seen Samsung offer visual voicemail on a Verizon phone. You can use Google Voice for free visual voicemail though.
    03-07-2016 10:18 AM
  3. Almeuit's Avatar
    I believe you have to use their app - https://play.google.com/store/apps/d...isualvoicemail.
    As for paying for it? Not sure. I would hope not .. VVM should be standard nowadays.
    03-07-2016 10:19 AM
  4. KimJongOMG's Avatar
    You're absolutely right! I was thinking of the premium visual voice mail which is 3 bucks a month.
    03-07-2016 10:31 AM
  5. dpham00's Avatar
    For a while now on the Samsung phones, the basic vvm is free. Premium vvm which includes voice to text will cost $2.99/mo
    Almeuit likes this.
    03-07-2016 10:54 AM
  6. keri2000's Avatar
    Awesome thanks everyone! I just want simple VVM so I'm really glad to know the simple version is free. Excellent!
    03-07-2016 11:00 AM
  7. KimJongOMG's Avatar
    The voice to text is the primary reason I switched to GV many years ago.
    jordans0nly likes this.
    03-07-2016 11:14 AM
  8. dpham00's Avatar
    I don't want to give Verizon $2.99 more... Not because it would break the bank... But more of on principal. Charging for bs. I don't have a texting plan either.
    03-07-2016 01:49 PM
  9. KimJongOMG's Avatar
    Exactly. That's why I use GV instead of paying Verizon $3 a month for something I can get for free from Google.
    03-07-2016 02:12 PM
  10. Jayq330's Avatar
    I don't see this anywhere on the internet, but I'm able to get to my voicemail the Android's visual VM...I need the Google visual voicemail to activate *VVM in call log history* & it's works most of the time, but sometimes it doesn't load the message & you can't hear it. I'm sure a dev can fix this, but nowhere in the web have i seen any case native Androidd VVM for galaxy s7, what they assume is Android native is the third party crapware. Their isn't enough known of this, so barely no one knows this can be done & to to it if it's the very same Android VVM UI that was recently shown to be in the Android M. So yeah we can have native VVM & not the third party crap, if only more people knew about this.
    06-09-2016 11:34 AM
  11. dmarcus48's Avatar
    Visual voice mail is free on the S7, no charge.
    06-09-2016 08:37 PM
  12. dpham00's Avatar
    For basic vvm, yes. Premium is $2.99 and includes voice to text and a larger mailbox.
    06-09-2016 10:09 PM
  13. Ph0enix13's Avatar
    The app says it isn't getting VVM data from Verizon. How do you correct this?
    08-08-2016 12:08 PM
  14. lterry913's Avatar
    I only get regular voice mail on s7. If I press visual voice mail in application drawer it tells me I have to pay 2.99. What's up? How do I fix?
    08-10-2016 05:45 PM
  15. underway99's Avatar
    The VVM in the Apps drawer might take you to Verizon's Premium Voice Mail, which costs $2.99. I don't have that app on my VZW S7e. I have the regular VM app. Look for red icon with a white VM graphic, labeled Voice Mail.
    08-10-2016 05:54 PM
  16. sciblades's Avatar
    Can some one post the apk my unlocked s7 doesn't have the app and I can't seem to find it
    08-10-2016 08:23 PM
  17. underway99's Avatar
    The rules here don't allow the posting of APKs or direct APK links. You should be able to find something with a Google search though.
    Good luck.
    08-10-2016 08:40 PM
  18. underway99's Avatar
    The problem may not be on your phone, but on an account setting on Verizon's end.
    I had some difficulty setting up VM with my LG G4 last winter. I did everything right on the phone, but still had no VM. I called Verizon tech support, and they hit a switch or something and made it work.
    08-10-2016 08:46 PM
  19. Carol Adams's Avatar
    Visual voice mail may be free on S7 but it doesn't work. I get an error saying "Sorry we ran into a problem with your order. Please call customer service at 800 922-0204 from a different phone to complete your order." i don't have a different phone and when I call I just get recordings that don't address the issue.
    08-24-2016 11:54 AM
  20. Carol Adams's Avatar
    08-24-2016 12:11 PM
  21. jordans0nly's Avatar
    Have mobile data turned on? Since VVM runs over the data section of the network, has to be on to get it. Also, doesn't work with power saving mode on. Hope this helps.
    08-27-2016 12:28 AM
  22. dpham00's Avatar
    Basic vvm is free. Premium costs$2.99
    11-03-2016 08:33 PM
  23. amyf27's Avatar
    Those on Verizon are you guys able to pay down your phone a little quicker when you feel like it ? Verizon rep said I could and I'm debating moving to Verizon
    11-07-2016 09:09 AM
  24. Dr Claw's Avatar
    You have 2 options: pay the installment, or pay the complete balance. you can't pay more toward your phone a month to get the balance down.
    11-07-2016 09:52 AM
  25. amyf27's Avatar
    They said I could if I called in. Said pay any amount over the monthly bill due and call in noting extra to go toward the phone
    11-07-2016 09:54 AM
27 12
  1. Replies: 1
    Last Post: 03-08-2016, 09:10 AM
  2. How can I tell if Doze is working on my Samsung Galaxy S7 Edge?
    By janderson1271 in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 07:21 AM
  3. Galaxy S5 email problem, can I get some help?
    By Alexphilly69 in forum Samsung Galaxy S5
    Last Post: 03-07-2016, 05:21 PM
