1. toshbar's Avatar
    Do third party apps work with the edge bar? Also, do they show in the always on display? let's say I want to use Textra for my messaging app. Will I be able to see textra notifications in the always on display? Or just samsung apps?
    03-07-2016 03:01 PM
  2. dpham00's Avatar
    Third party apps don't shoe on the always on display
    03-07-2016 03:02 PM
  3. toshbar's Avatar
    do you know if they commented on it?
    03-07-2016 03:10 PM
  4. meyerweb#CB's Avatar
    Samsung is opening up the APIs for the edge bar so third party developers can make use of it. I'm not sure if that will be true for the AOD or not. Even if so, it will be up to individual devs to decide to incorporate those features. Some will, many won't. I can't see Google adding Samsung AOD support to its apps, for example.
    03-07-2016 03:50 PM
  5. Adiliyo's Avatar
    i think for the AOD, it will be the other way around. samsung will most likely allow all notifications access to the display. kind of like how the split screen function only worked with a few apps, and now works with significantly more.
    that's my hope anyways.
    03-07-2016 04:38 PM
  1. S7 issues
    By ulnek in forum Samsung Galaxy S7
    Last Post: 07-14-2016, 07:30 PM
  2. Replies: 1
    Last Post: 03-08-2016, 06:43 PM
  3. Advantages of Edge over S7
    By ulnek in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 05:09 AM
  4. Galaxy S7 Edge Protective Plastic
    By pwinters in forum Samsung Galaxy S7 edge
    Last Post: 03-07-2016, 06:33 PM
  5. Messaging app for Android wear
    By eric002 in forum Ask a Question
    Last Post: 03-07-2016, 02:55 PM
