Has anyone with an S7/Edge confirmed that Package Disabler Pro works? That app was a life saver on the Note 5...
free version any good?
..so you just use the app to remove the unwanted crap and delete the app afterwards?? For $2? Does it serve any other purpose after you've done the initial "purge"?
Yeah pretty sure deleting the app would bring everything backDon't delete it. Pretty sure that will reverse everything. Plus, before any software update you should re-enable everything. Beauty of this is that you can export your settings to an XML file and then import it back following the software update, so you don't have to go through and check everything again.
Does this do anything different than what going into application manager does when hitting disable?
I usually only end up disabling most of the ATT apps.
i'd like to know this as well
