03-12-2016 04:03 PM
34 12
tools
  1. Furt's Avatar
    Has anyone with an S7/Edge confirmed that Package Disabler Pro works? That app was a life saver on the Note 5...
    03-07-2016 11:32 PM
  2. dpham00's Avatar
    It works.
    optimummind and Furt like this.
    03-07-2016 11:37 PM
  3. clsdv's Avatar
    Yup already using it.
    Furt likes this.
    03-08-2016 02:03 AM
  4. sangs's Avatar
    03-09-2016 04:06 PM
  5. tyk5054's Avatar
    free version any good?
    03-09-2016 04:32 PM
  6. sangs's Avatar
    Not sure. I splurged the $1.95 for the Pro version though
    03-09-2016 04:42 PM
  7. 78standards's Avatar
    ..so you just use the app to remove the unwanted crap and delete the app afterwards?? For $2? Does it serve any other purpose after you've done the initial "purge"?
    03-09-2016 04:44 PM
  8. Almeuit's Avatar
    That is good to hear it works. I may need it if T-Mobile won't let me disable that stupid account app >.<
    03-09-2016 04:44 PM
  9. Almeuit's Avatar
    Well some apps you can't delete since they're system apps. If I recall correctly the app just gets it disabled.
    78standards likes this.
    03-09-2016 04:44 PM
  10. AlphaVictor87's Avatar
    Does this do anything different than what going into application manager does when hitting disable?
    I usually only end up disabling most of the ATT apps.
    03-09-2016 04:52 PM
  11. sangs's Avatar
    Don't delete it. Pretty sure that will reverse everything. Plus, before any software update you should re-enable everything. Beauty of this is that you can export your settings to an XML file and then import it back following the software update, so you don't have to go through and check everything again.
    03-09-2016 05:44 PM
  12. nickster0824's Avatar
    So I bought the app!
    Should I select the "Disable all bloatware" or select them one by one?
    03-09-2016 06:06 PM
  13. limitbreak09's Avatar
    Bought the app too. Worth it!!
    03-09-2016 06:25 PM
  14. nickster0824's Avatar
    Did you just select to disable all the bloatware apps or go through all of them one by one?
    03-09-2016 06:35 PM
  15. dpham00's Avatar
    Yeah pretty sure deleting the app would bring everything back
    03-09-2016 06:46 PM
  16. Adiliyo's Avatar
    i'd like to know this as well
    03-09-2016 06:57 PM
  17. gringoaplatanado's Avatar
    It does the same thing but somehow allows you to disable things such as system apps that normal methods do not... well worth the pocket change for what it does without having to have root.
    03-09-2016 07:37 PM
  18. dpham00's Avatar
    Most definitely. It let's you disable a lot more than what you could do in the apps manager
    03-09-2016 07:57 PM
  19. nickster0824's Avatar
    So from what I've been reading, disabling certain things through this app can cause issues with Samsung Pay and few other functions.
    Does anyone happen to have a list or anything showing which is OK to disable?
    03-09-2016 08:17 PM
  20. vr002sh's Avatar
    you really need to understand what apps you use and why. for example if you disable NFC, Samsung Pay (or Android Pay) will not work as they use NFC to communicate with the card reader.
    The author considers Chromecast as bloatware, but I use it frequently. Most of the "pink" items can be disabled safely, but again, you should make your choices. If you disable Smart Manager (I would love to), then you cannot view your battery control panel, so keep that one.
    I do have a list, and I could export it, but frankly, my list would be different than yours. I am happy to try to answer individual, how about this one, kinds of questions.
    There is a real expert on PDP here that frequents the boards, I cant remember his name, but once I see it, I will know it. Hes the real guy to listen too.
    03-09-2016 10:07 PM
  21. adelcastillo78's Avatar
    So in exchange to all the bloatware, you just have one app that you can't get rid of... becoming a paid bloatware...
    03-09-2016 10:17 PM
  22. KimJongOMG's Avatar
    How is an app the user installs on to the phone bloatware? The things take up less than 9MB so it's not taking up a huge amount of space and was installed voluntarily.
    MoshuXXL likes this.
    03-09-2016 11:07 PM
  23. sangs's Avatar
    Sounds like somebody doesn't quite grasp the definition of bloatware.
    03-10-2016 06:40 AM
  24. nyywarrior21's Avatar
    Just wanna make sure I'm getting the right app - it's developed by police developer?
    03-10-2016 01:59 PM
  25. walkman666's Avatar
    Yes. I am using it for the first time, too. I initially selected disable all bloatware, and then have selectively re-enabled some "bloatware" based on some google searches of specific apps.
    sangs likes this.
    03-10-2016 02:27 PM
34 12
  1. Why is my settings disable in talkback?
    Last Post: 03-11-2016, 01:30 AM
  2. Samsung 128gb Pro + Micro sd on sale for $89.99
    By paulphilly in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 02:47 PM
  3. Samsung Tab S - No WiFi or Bluetooth (disabled?)
    By sggarcon in forum Samsung Galaxy Tab S 10.5
    Last Post: 03-09-2016, 06:36 PM
  4. Disable Camera Function?
    Last Post: 03-07-2016, 07:16 PM
  5. can I disable the hold feature during phone calls
    Last Post: 03-06-2016, 02:01 PM
