1. Byron Hinson1's Avatar
    Had the phone since this morning and love it but the battery doesn't seem so great compared to what some people have said
    Mine seems to go down by 5% every 10 mins of use.
    Checking the battery usage shows the Google app as the main battery user yet I'm not running it on screen. Has anyone else got the same issue.
    03-08-2016 12:29 PM
  2. tshirttan408's Avatar
    Have you disable location services, (think it's history). If I've ever had a huge drain it tends to be that.
    03-08-2016 12:47 PM
  3. Techno-guy's Avatar
    First few days consists of an enormous number of updates as well as indexing. Your drain seems really high but I usually keep my brand new phones plugged in while they are doing the heavy updating for the first few hours after set-up. Once it settles in, the battery life of the S7 edge is phenomenal.
    03-08-2016 01:30 PM
  1. Auto Advance on native email app?
    By Rogie in forum Samsung Galaxy S7 edge
    Last Post: 08-22-2016, 01:07 AM
  2. Replies: 8
    Last Post: 03-10-2016, 05:42 PM
  3. Why LG G3 restarts? Why some apps have 1970 years date?
    Last Post: 03-09-2016, 01:46 PM
  4. What Galaxy S6 themes use the least battery power?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-09-2016, 08:46 AM
  5. Replies: 2
    Last Post: 03-08-2016, 11:08 PM
