1. scavok's Avatar
    Hello all!
    UPS dropped off my phones at home. One phone being upgraded is an S5. Will the S5 SIM card go into the S7? I vaguely remember when I got the S6 the SIM cards were a touch different. Is this true? Or is it a drop in and play?
    Thanks!
    03-08-2016 11:30 AM
  2. B. Diddy's Avatar
    The S5 uses a microSIM, while the S7 uses nanoSIM. So you'd need to use a SIM card cutter for your current card, or get a new SIM from your carrier.
    03-08-2016 12:23 PM
  3. jschu22's Avatar
    Were the phones bought on existing lines? If so, doesn't the phone activate itself (with the included sim) once you power it on?
    03-08-2016 12:27 PM
  4. NexusGirlX's Avatar
    That may depend on the carrier. With T-Mobile, when you upgrade to a newer phone, they still include a new sim card even though all you have to do is place the sim from the old phone into the new phone. Also with T-Mobile, if the phone uses a different sim then the old phone, you can just login to your account and use the site to activate a new sim without calling in.
    The OP hasn't said what carrier they are on.
    B. Diddy likes this.
    03-08-2016 12:43 PM
  5. scavok's Avatar
    The SIM card is different. I purchased both phones outright since one was not eligible. I called AT&T and got me all set up in 5 minutes.
    03-08-2016 02:51 PM
  6. kpreachers's Avatar
    Hello all!
    Thanks!
    I upgraded from the S5 and I had to put in a new SIM card. I was up and running in about two minutes since the new card was already ready be popped in and activated.
    03-08-2016 08:12 PM
  1. Why can't I save photos on an internal-formatted SD card?
    By AC Question in forum Moto G (2015)
    Last Post: 06-09-2016, 12:20 PM
  2. Why message Invalid Sim Card on Galaxy Grand Prime?
    By AC Question in forum Samsung Galaxy Grand
    Last Post: 05-01-2016, 01:15 PM
  3. Can I use phone without SIM to view WhatsApp messages?
    By RamDev83 in forum WhatsApp for Android
    Last Post: 03-09-2016, 05:47 AM
  4. How to view Whatsapp chats on a phone without a sim ?
    Last Post: 03-08-2016, 04:16 PM
  5. "sd card" Please help!!!
    By Angel Rose2 in forum Ask a Question
    Last Post: 03-08-2016, 12:45 PM
