1. Steve Wellens's Avatar
    just switched over from iphone. I work different days each week and need to be able to turn my alarm on and off. The only function I can find with the S7 edge is to delete the alarm if I don't want it to go off on a certain day and recreate the alarm for the days I work. I found an app (Timely) that allows me to turn it off and on like my iphone but I'd rather use the native app if possible to save space. Am I missing something? Thanks in advance for any help
    P. S. I Fu*king love this phone. Don't know why I switched to iphone in the first place.
    03-08-2016 11:59 AM
  2. Dimeezy's Avatar
    On my Note 5, I press the alarm ⏰ symbol to the far right to turn that alarm off
    03-08-2016 12:07 PM
  3. Steve Wellens's Avatar
    That was it. I knew it was something simple. Thanks. Its on the left on mine.
    03-08-2016 02:59 PM
  1. S7 Edge "Always on Display" with Clear View case problem
    By Rensu in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 05-21-2018, 03:47 PM
  2. S7 Edge "Always on Display" with Clear View case problem
    Last Post: 03-08-2016, 12:30 PM
  3. Replies: 1
    Last Post: 03-08-2016, 12:26 PM
  4. Can the Repo tool work with BitBucket git repository?
    Last Post: 03-08-2016, 11:24 AM
  5. Email that works with calendar?
    Last Post: 03-08-2016, 10:58 AM
