1. Averix's Avatar
    Looking for some quick feedback on the different carrier versions to see if they included a setting to change the duration or turn off the bottom back and apps buttons' backlights. Trying to see if my app will work with all the S7 Edge variants out there and/or if the carriers included the setting this time around.
    https://play.google.com/store/apps/d...xybuttonlights
    03-08-2016 01:19 PM
  2. clsdv's Avatar
    It works Im using it on mine and have them set to off. I like the clean black look.
    Averix likes this.
    03-08-2016 02:13 PM
  3. jschu22's Avatar
    Works great, thank you!
    03-08-2016 05:58 PM
  1. Power button stopped working
    By conquerall in forum Samsung Galaxy S3 Mini
    Last Post: 03-08-2016, 06:30 PM
  2. Replies: 3
    Last Post: 03-08-2016, 05:38 PM
  3. Replies: 2
    Last Post: 03-08-2016, 04:44 PM
  4. Replies: 1
    Last Post: 03-08-2016, 04:24 PM
  5. Power button stopped working - Galaxy S3 Mini. How can I fix it?
    By AC Question in forum Samsung Galaxy S3 Mini
    Last Post: 03-07-2016, 04:11 PM
