1. dannii169's Avatar
    I have just moved to android from iphone, so far getting on alright. but one thing i really miss, is the ability to lock the volume of the ringtone, then just use the volume controls on the side for media play back?
    Am I missing something?
    Using a Samsung S7 edge
    Please help
    03-08-2016 02:04 PM
  2. B. Diddy's Avatar
    Welcome to Android Central! I'm not sure if this does what you're asking, but give Volume Control + a try.
    03-08-2016 02:29 PM
  1. S7 Edge "Always on Display" with Clear View case problem
    By Rensu in forum Samsung Galaxy S7 edge Cases & Accessories
    Last Post: 05-21-2018, 03:47 PM
  2. Replies: 3
    Last Post: 03-08-2016, 05:38 PM
  3. Replies: 5
    Last Post: 03-08-2016, 03:32 PM
  4. Can I get some help with my clock/alarm function?
    By Steve Wellens in forum Samsung Galaxy S7 edge
    Last Post: 03-08-2016, 02:59 PM
  5. S7 Edge "Always on Display" with Clear View case problem
    Last Post: 03-08-2016, 12:30 PM
