03-12-2016 06:48 AM
40 12
tools
  1. KimJongOMG's Avatar
    There isn't a more option?
    I can clearly see your email address. Might want to delete that picture.
    Your app looks different than mine. Are you using the stock Samsung Calendar app?
    03-11-2016 12:20 AM
  2. lady of the lake's Avatar
    The calendar shows up when you slide out the "edge". I couldn't find it at first either.
    Ladyofthelake
    03-11-2016 01:35 AM
  3. KimJongOMG's Avatar
    Ladyofthelake
    It's also in the Samsung folder
    03-11-2016 01:43 AM
  4. LMychajluk's Avatar
    Really been liking MS' Outlook App for mail and calendar recently, but I suppose it depends on which calendars you access.
    MS Outlook makes it easy to work with my Office365 account and Outlook on a PC. Office365 doesn't seem to present itself as an Exchange Server, so the app kind of has to support it specifically for full featured use. Outlook also allows me to add my own Google calendars (but not other's shared Google calendars), which you can see w/ the Samsung calendar (or Google Calendar).
    If you're working
    03-11-2016 03:11 PM
  5. bsteppuhn's Avatar
    Google calendar. You can share your calendar with someone else and change the permissions so they can also add and remove events. Basically, 2 owners of 1 calendar. It syncs with the stock app and this is what I have my employees using. This way, I know the exact estimated time and date my designers and managers will be finished with a task or when merchandise is coming in so I know what's going on in all departments without holding a meeting every 15 minutes.
    Love Google calender. But so far everything is syncing in this. Kim does it still work if someone adds a date? I'm using the samsung one right now but all my stuff synced. If I add the date in this app will it sync to the others or do I need the actual google calender app?
    03-11-2016 03:40 PM
  6. sangs's Avatar
    Samsung one works perfectly with my Google account. I've tried others, but never seem to need the bells and whistles a lot of them offer.
    03-11-2016 03:45 PM
  7. KimJongOMG's Avatar
    As long as when you create the event, it's set on the right Google calendar, it syncs up just fine.
    03-11-2016 04:11 PM
  8. TMavC5's Avatar
    Loving my s7e. Currently using nova and I don't see the samsung calendar widget. I'm looking for recommendations on the best calendar app and widget or reallt any other app recommendations. Thanks!
    https://play.google.com/store/apps/d...droid.calendar
    03-11-2016 05:10 PM
  9. bsteppuhn's Avatar
    Thanks!
    03-11-2016 06:20 PM
  10. jdfry15's Avatar
    I've been using business calendar the last couple years. I think they have the best widgets.
    03-11-2016 06:56 PM
  11. Captpt's Avatar
    aCalendar+ is good.
    I'm looking aCalendar but can't figure how to make it default to Month view when I open it??
    03-11-2016 10:53 PM
  12. zipro's Avatar
    Google's own calendar app is very good. You can find it on the Play Store
    03-11-2016 11:00 PM
  13. dman76's Avatar
    Under settings, there is an option for the start view.
    Captpt likes this.
    03-12-2016 12:42 AM
  14. Captpt's Avatar
    Thank you, I can't believe I missed that lol..
    Now its the perfect calendar app
    03-12-2016 06:20 AM
  15. PsychDoc's Avatar
    aCalendar+ is good.
    What he said! ^
    03-12-2016 06:48 AM
40 12
  1. Samsung Galaxy S7 Edge - how to access in app settings...?
    By Stigasteve23 in forum Samsung Galaxy S7 edge
    Last Post: 10-18-2016, 10:54 PM
  2. Replies: 1
    Last Post: 03-25-2016, 04:50 PM
  3. were i can find the stockrom for my samsung galaxy note?
    Last Post: 03-11-2016, 11:11 PM
  4. Replies: 0
    Last Post: 03-11-2016, 11:10 PM
  5. Replies: 0
    Last Post: 03-11-2016, 10:40 PM
