06-26-2016 01:05 PM
29 12
tools
  1. ApexPredation's Avatar
    Nice! I'm glad to hear it's working for others too. It's probably one of the most bizarre fixes I've ever encountered.
    03-17-2016 01:20 PM
  2. TT_7's Avatar
    I fixed it but couldn't get it to work the way that was described above.
    Here's what I ended up doing.
    I think I had DND turned off and then I turned the volume all the way down using the volume rocker buttons. When it was all the way down, I turned it down one more click. I then slid it open from the top and clicked the DND button to turn it on. I then clicked the DND notification panel and it opened automagically!
    Hopefully this or some variation helps some people.
    Good luck.
    Now I just want it to turn off DND based on my alarms, like my CM-rooted LG G3 would do.
    04-19-2016 04:22 PM
  3. Andrew Saint's Avatar
    Is anyone else finding it crashes when you try to open it in settings?
    Turned on Do Not Disturb from Notification Tray, Click and Hold on the Notification for Do Not Disturb that shows Turn Off. System UI Apple Settings will pop up, click on blue icon wI think an i on it. Clear Cache and Data, I think only Cache option was available. After that, settings for Do Not Disturb worked perfect.
    06-26-2016 12:43 PM
  4. fsfty's Avatar
    Works fine on Verizon
    06-26-2016 01:05 PM
29 12
  1. Power/Lock button not working?
    By Bad_Robot in forum Samsung Galaxy S7
    Last Post: 12-02-2018, 11:50 AM
  2. how do i find the voice mail on my motorola cell phone
    Last Post: 03-08-2016, 10:57 PM
  3. LG G4 can you add a spam folder in email?
    Last Post: 03-08-2016, 08:22 PM
  4. Is the edge on the SGS7 hard to get used to?
    Last Post: 03-08-2016, 08:07 PM
  5. My Galaxy S4 will not sync with facebook.
    Last Post: 03-08-2016, 08:01 PM
