06-26-2016 01:05 PM
29 12
tools
  1. SteveISU's Avatar
    Is anyone else finding it crashes when you try to open it in settings?
    03-08-2016 09:00 PM
  2. dpham00's Avatar
    Have you used package disabler?
    Sent from my Verizon Samsung Galaxy Note 5
    geekaren likes this.
    03-08-2016 09:11 PM
  3. SteveISU's Avatar
    No, I got into settings and anytime I tap on do not disturb settings crashes.
    03-08-2016 09:21 PM
  4. David Brock's Avatar
    I'm having the same issue with it on my S7.... (non edge)
    03-08-2016 10:39 PM
  5. dpham00's Avatar
    I would try to clear data on the settings app.
    03-09-2016 09:34 AM
  6. jdphilly's Avatar
    Have anyone found a solution yet? might have to return my device
    03-09-2016 08:00 PM
  7. freedomx20a's Avatar
    Probably a Marshmallow bug.
    It's a very buggy os compared to Lolli
    posted via the lovely innovative Priv by BlackBerry - Powered by Android
    03-09-2016 08:13 PM
  8. muaddip's Avatar
    Just got my S7 Edge and settings crashes every time I try to go into the Do Not Disturb. Definitely something up with the S7, I have not problem with my Turbo 2 that was on Marshmallow. Hope they get it fixed soon, I really liked DND.
    03-09-2016 09:29 PM
  9. M3Rocket's Avatar
    Yes--this is also crashing "Settings" on my S7 Edge on AT&T. I've tried everything including resetting the phone. I suppose we're SOL till Samsung fixes this?
    03-10-2016 04:14 AM
  10. elir41's Avatar
    Same thing here.
    Edit: I'm on Verizon.
    03-10-2016 06:17 AM
  11. Dukins's Avatar
    Working fine for me, Verizon. It maybe carrier specific. Might help to include carrier.
    03-10-2016 06:28 AM
  12. pst23's Avatar
    No crash here on AT&T
    03-10-2016 06:46 AM
  13. Dukins's Avatar
    And there we have it, my theory has been debunked lol.
    03-10-2016 06:51 AM
  14. ApexPredation's Avatar
    Unlocked European version S7 here, I'm having the same problem.
    03-10-2016 02:13 PM
  15. dpham00's Avatar
    Working fine on Verizon.
    03-10-2016 05:28 PM
  16. SiWoody7's Avatar
    Yes I am getting the same thing with my Samsung Galaxy S7 on Vodafone in the UK. I have the normal S7 not the edge.
    03-11-2016 12:33 PM
  17. SiWoody7's Avatar
    Oh and I have tried a factory reset and I still have the same problem. Its obviously a software issue that Samsung need to acknowledge and send out a fix. To be clear the pull down menu blue button works fine but this does not allow you to set automatic DND times. Its the orange Do not disturb button in the actual menu results in my phone saying "Unfortunately, Settings has stopped". This is the only issue I have found using my new S7 on Vodafone in the UK. I have the normal S7 not the edge.
    03-11-2016 12:43 PM
  18. SIOP's Avatar
    I went to Silence Premium a long time ago and love it.
    03-11-2016 01:05 PM
  19. ApexPredation's Avatar
    Possible Fix...
    TL;DR Toggle DND on from quick settings. Plug into charger. Open clock app and start setting alarm. (possibly need to receive a message, it was an email for me.) Pull down notifications and tap DND notification... Success! (Hopefully)
    Last night I had my device in DND mode from the notifications toggle. I plugged it in to charge then went into the clock app to set an alarm. While i was in the middle of that I pulled down the notification tab to check a message that just came in and accidently tapped the DND notification instead. Miraculously it worked and went into the DND settings. Now it works like normal.
    03-12-2016 09:05 AM
  20. H0g4n's Avatar
    Clearing data for the Settings app resolved this issue for me.
    Settings > Applications > Application Manager > Settings > Storage > Clear Data
    The app will close since you just reset it.
    Open Settings again and DND now works.
    03-12-2016 09:49 AM
  21. ApexPredation's Avatar
    Its definitely worth the try, but doing that didn't help me. Even going into recovery and deleting cache didn't help. For some odd reason it got fixed when I did what my previous post explained. I have no clue how that made it work but DND is working like normal now.
    03-12-2016 03:18 PM
  22. SiWoody7's Avatar
    Hi all thanks for all the messages. I have resolved the issue by conducting a factory reset and ignoring the setup prompts and getting to the menu ASAP. Looking at the menu I could see that the do not disturb settings to schedule DND times was present and correct. I then had to log into my Google account, Samsung account and down load the apps and setup the phone manually without working from any backups and now all the menus work.
    I had already completed a factory reset the day before using all the prompts and backups available and the issue was still there. I can only assume there is a problem with the setup wizard or the backups created the issue?
    So to conform I no longer have an issue.
    Many thanks Simon
    03-14-2016 06:36 AM
  23. Kjax016's Avatar
    Holy crap. This actually worked.
    Possible Fix...
    ApexPredation likes this.
    03-15-2016 10:57 PM
  24. brianswst's Avatar
    WOW. Worked, but I had to unplug after playing with clock and receiving a message.
    03-16-2016 07:07 PM
  25. meyerweb#CB's Avatar
    No problem here (Sprint). Went into settings to DND, turned it on, changed settings, exited, when back in and turned it off. No crashes.
    03-16-2016 10:52 PM
29 12
  1. Power/Lock button not working?
    By Bad_Robot in forum Samsung Galaxy S7
    Last Post: 07-11-2018, 05:02 PM
  2. how do i find the voice mail on my motorola cell phone
    Last Post: 03-08-2016, 10:57 PM
  3. LG G4 can you add a spam folder in email?
    Last Post: 03-08-2016, 08:22 PM
  4. Is the edge on the SGS7 hard to get used to?
    Last Post: 03-08-2016, 08:07 PM
  5. My Galaxy S4 will not sync with facebook.
    Last Post: 03-08-2016, 08:01 PM
