05-05-2016 12:59 PM
45 12
tools
  1. AC Question's Avatar
    I just received my Galaxy S7 Edge and was super stoked until this AM when I pulled up my iHEART app up and the phone gets hotter then a pizza oven and cuts off over and over again. Is this a software issue or an app issue? I called AT&T and they said I can return the device but I really do like it and would like to keep it. Just confused and wondering if I have a bad device or this is a software issue.
    I have turned the phone completely off (5 min) and turned it back on several times still having the same issue. I have even removed and re installed the app with the same trouble.
    03-09-2016 09:12 AM
  2. B. Diddy's Avatar
    Welcome to Android Central! Does this happen on both wi-fi and mobile data? Have you tried going to the App Manager, selecting iHeart, and Clearing Cache/Data?
    03-09-2016 06:27 PM
  3. JasonBST's Avatar
    Thanks for the reply. Yes I tried both. I finally deleted the app and contacted Samsung. They entered an escalation ticket. I will post on here what the solution is.
    B. Diddy likes this.
    03-10-2016 07:09 AM
  4. dmlv's Avatar
    Happened to me as well but only when using the app with Bluetooth headphones.
    03-10-2016 07:16 AM
  5. andrew_ackley's Avatar
    Maybe it has to do with the iheart radio app specifically not being optimized for marshmallow?
    03-10-2016 07:52 AM
  6. dmlv's Avatar
    I have had the Nexus 6p since launch and iheart works flawlessly on it....oh well
    03-10-2016 08:32 AM
  7. Snider8419's Avatar
    I have a S7 that is doing the same thing. The streaming will stop and when I look at the phone it will be rebooting. I have it linked thru my Bluetooth to my car when it happens. Mine is thru Verizon and i called them about the problem. I was able to stream Pandora with no problems so it must be a problem with the iheart app.
    03-11-2016 11:33 AM
  8. JasonBST's Avatar
    I know I can use Milk Music (samsungs music app) or Pandora. Samsung claims to be looking into the problem.
    03-11-2016 11:55 AM
  9. JasonBST's Avatar
    I thought that was it as well but I updated my other device which is operating on Marshmallow so who knows. Thanks for everyones input thus far :-) Ill keep everyone posted with what AT&T or Samsung tell me.
    03-11-2016 11:58 AM
  10. Matt-Helm's Avatar
    Same problem here...
    03-11-2016 12:02 PM
  11. Nkky7's Avatar
    Hi, how do I contact Samsung?their website? Something similar happened to me but while using the YouTube app while linked to the TV.
    03-11-2016 12:02 PM
  12. clintw22's Avatar
    I'm having the exact same problem. Verizon s7 edge. Streamed iheart radio thru Bluetooth and it stopped when I was in the shower and when I got out, my phone had restarted. Don't know if it got hot.
    03-11-2016 12:06 PM
  13. Snider8419's Avatar
    I tried to Uninstaller and reinstall app to see if that would help but it didn't. Tried turning off the battery fast charge with no help. Tried just using the speaker without using blue tooth but still no help. I used the phone for a long time and it got kind of hot but never rebooted like it does with iheart app running.
    03-11-2016 01:46 PM
  14. JasonBST's Avatar
    Yes on the website. Just click Owners & Support and then on the drop down click contact support. Fill out the needed info and submit. They are pretty quick about getting back to you. My issue with iHeart must be a big problem it has been escalated to an executive level per my feedback from Samsung.
    03-14-2016 06:37 AM
  15. JasonBST's Avatar
    Yes its really odd. Sometimes it will run non stop without a problem and other times it crashes within minutes.
    03-14-2016 06:39 AM
  16. andrew_ackley's Avatar
    Leave a bad rating on the app about the issue and they will address it. Then you can just update the review.
    03-14-2016 11:44 AM
  17. Snider8419's Avatar
    The Iheart group was quick to respond to my email. They had me do this and I have been able to listen for over 30 minutes without problems First, please sign out of iHeartRadio. Only things is I didn't have a option to clear cache.
    Press or tap your device’s Home button or icon OR tap your device’s Menu button or icon Tap Settings (or System Settings) Tap Application Manager (or Apps) Swipe up to find iHeartRadio and tap the app icon Tap Force Stop Tap Clear Cache Tap Clear Data
    Next, please uninstall iHeartRadio from your device. Do not re-install just yet, only uninstall iHeartRadio.
    Then, could you then please try powering down your device. Leave the device powered down for around 30 seconds. After that, you may power the device back on and reinstall iHeartRadio
    03-14-2016 12:32 PM
  18. JS_racer's Avatar
    wtf, really ??? lol
    my wife mentioned this rebooting, so i tried it on mine,in under 5 minutes, rebooted.
    looking for a fix, not sure what that does. please keep us posted.
    thanks!!
    03-14-2016 02:27 PM
  19. sj98ta's Avatar
    So, interesting. I uninstalled the iHeartRadio app on my S7, and then tried to re-installed, and can't. The iHeartRadio app in the Playstore says it is not compatible with the device. I wonder if this will be permanent, or just until they come up with a fix?
    03-16-2016 05:42 AM
  20. JS_racer's Avatar
    looks like a new update today!!
    who is first ??? lol, not me!!
    03-17-2016 02:58 PM
  21. Snider8419's Avatar
    It has been working good for me all since I reinstalled it awhile back, but this is their response.
    A new version of the iHeartRadio app (6.0.1) is going to be released to the beta community shortly. Thank you so much for your patience and understanding in this matter.
    03-18-2016 12:37 PM
  22. saintdaniel's Avatar
    i also have and HAD the same issue,removed iheart it stopped the rebooting.
    03-18-2016 09:14 PM
  23. manusbaldspot's Avatar
    Happened to me as well. I thought it was enxomondo at first.
    03-18-2016 09:25 PM
  24. JS_racer's Avatar
    the update on the 17th said it was again compatible with our phones, have not tried it yet, any one ??
    03-19-2016 06:21 AM
  25. clintw22's Avatar
    I uninstalled and reinstalled and it works fine for me so far. But it's only been a day.
    03-19-2016 07:34 AM
45 12
  1. S7 & Edge stock firmware downloads
    By ironass in forum Samsung Galaxy S7
    Last Post: 05-14-2016, 04:53 AM
  2. Always On Display - You leaving on or off?
    By felloffthetruck in forum Samsung Galaxy S7 edge
    Last Post: 03-16-2016, 03:05 AM
  3. How do I check a voicemail that has been saved to a folder?
    Last Post: 03-09-2016, 06:29 PM
  4. How to change the OS of SKK mobile (cheap china phone)
    Last Post: 03-09-2016, 08:52 AM
  5. How long should I charge a new phone before the first use?
    Last Post: 03-09-2016, 08:46 AM
