1. nyywarrior21's Avatar
    I just received my edge and want to make sure the transfer from the iPhone to the edge goes smooth. I've had android phones in the past and have always had issues with iMessage deregistering. Is there anything to help avoid that issue?
    Are there any other things to do before switching over?
    Are there any must have apps for the phone?
    03-09-2016 01:13 PM
  2. wxman2003's Avatar
    turn off iMessage and Facetime on iPhone and then go here and deregister your phone number.
    https://selfsolve.apple.com/deregister-imessage/
    03-09-2016 01:16 PM
  3. KimJongOMG's Avatar
    It's been discussed recently and rather than try to organize everything, here is a pile of information!
    http://forums.androidcentral.com/sam...g-android.html
    How to disable and deactivate iMessage on iPhone or iPad | iMore
    http://forums.androidcentral.com/sam...ml#post5041680
    Package Disabler Pro is definitely an app you'll want to disable bloatware. Can't delete it, but you can shut it down for good.
    Also, use Samsung Smart Switch to make things easy when switching over.
    03-09-2016 01:21 PM
  4. nyywarrior21's Avatar
    thank you both!
    03-09-2016 05:26 PM
  5. nyywarrior21's Avatar
    so i followed these instructions before switching my phone and i'm not receiving messages from someone who has the iphone.
    What do you think could be causing that?
    03-09-2016 06:04 PM
  6. MizWylie's Avatar
    It can take up to 24 hours to break free of the Apple ecosystem. If you're in a hurry you can call them and cream the whole connection but it may still take 24 hours.
    Posted from the 6P of Aluminum Doom
    03-09-2016 06:25 PM
  7. dizzll's Avatar
    You have to tell your friends and family to delete all previous conversations you had with them on imessage. Then a new text will see that their is no imessage available at your end. Nothing else will work. Trust me, I have both systems and swap often. it's annoying as all hell.
    03-09-2016 06:47 PM
  1. Anyone else get the gear S update this morning?
    By castone001 in forum Samsung Gear S
    Last Post: 05-13-2016, 11:19 AM
  2. Where do I find my 6 free vr games from sprint?
    By smalba in forum Samsung Galaxy S7 edge
    Last Post: 03-25-2016, 04:38 PM
  3. Replies: 2
    Last Post: 03-10-2016, 11:01 AM
  4. Why is my Samsung galaxy s6 edge showing 'emergency calls only?
    By Lee Anderson1 in forum Samsung Galaxy S6 edge
    Last Post: 03-09-2016, 05:23 PM
  5. Replies: 2
    Last Post: 03-09-2016, 04:22 PM
