1. Mobyone01's Avatar
    I wanted to make a short list of the things we lost in touchwiz this time with S7... if anybody noticed more please post....
    So:
    Lockscreen effects!!!!!!!!!!!!!!!!!!!!!!!!
    Having a transparent notification bar!!!!
    The option to disable the back lighting for the recent apps and back buttons!!!!
    Being able to select which power saving options to be active when you have it on!!!
    Widgets like S music missing!!!
    Honestly thou, so far i am quite happy with what they've done with the device and some of the OS tweaks. But I really don't understand why they keep removing software options that will not cost them any extra time or money but will keep old samsung users like myself happy!?
    Please share your thoughts and opinions...
    03-09-2016 06:15 PM
  2. dpham00's Avatar
    Weather on lock screen
    Mobyone01 likes this.
    03-09-2016 06:21 PM
  3. dpham00's Avatar
    You can disable the back lighting for the capacitive buttons using the Galaxy Button lights app from the play store
    03-09-2016 06:22 PM
  4. Stigasteve23's Avatar
    No lockscreen effects? I enjoy the lockscreen effects! Bummer
    03-09-2016 06:54 PM
  5. SprintFun's Avatar
    My notification bar is transparent, but maybe because I'm using Nova?
    03-09-2016 07:03 PM
  6. xxINFIDELxx's Avatar
    The things we lost :(-screencapture.png
    I just selected themes from the menu where you can add widgets and wallpapers and now my notification bar is clear. Not sure if it was before in the default theme.
    03-10-2016 12:33 AM
  7. Mobyone01's Avatar
    Thanks everyone for all your replies. I realized that the grey notification bar I had was becaus I had the power saving mood on permanently! So basically you get an ugly looking bar if you want to save some battery power!!!
    03-10-2016 01:33 AM
  8. Dukins's Avatar
    Is there a S-Planner widget? I can't find it anywhere. I like have an agenda widget view. I've been off Android for a year now, just want to make sure I'm not missing anything.
    03-10-2016 07:08 AM
  9. Mobyone01's Avatar
    Yes, this one is still there. Thank God!
    Still under the name S Planner
    03-10-2016 07:12 AM
  10. Mobyone01's Avatar
    I just found another one missing:
    The Smart Manger Widget does not show the Battery and Guard status anymore
    03-10-2016 07:15 AM
  11. Dukins's Avatar
    Did you have to download from samsung app? Im a dunce I guess, too much time on Apple.
    sangs likes this.
    03-10-2016 07:23 AM
  12. Mobyone01's Avatar
    No I didn't have to, but it might not be preinstalled on all the variants. So if you don't find it under Settings > Home Screen > Widgets. Then go to the Galaxy Apps store and download it there
    03-10-2016 07:27 AM
  13. Dukins's Avatar
    Thanks for your prompt response. I can't find it on the Verizon variant or I can't find how to view screen on time. Previously Settings > Battery > Show Screen on. My Battery isn't displaying screen on time. This is getting wierd.
    03-10-2016 07:43 AM
  14. dhenry11's Avatar
    Active Applications widget?
    03-10-2016 07:57 AM
  15. Stigasteve23's Avatar
    Sooooo there really is no lockscreen effect? Lol I enjoy this feature on all my samsung phones
    03-10-2016 08:14 AM
  1. How can I get rid of the ads on my home screen permanently
    By John246980 in forum Samsung Galaxy S6
    Last Post: 09-11-2017, 04:02 PM
  2. What have you found in the N preview so far?
    By Aquila in forum Android 7.0 Nougat
    Last Post: 08-02-2016, 05:14 AM
  3. What the hell is wrong with my screen?
    By Gurilla in forum General Help and How To
    Last Post: 03-10-2016, 04:43 PM
  4. Does Foxfi work with the Priv on Verizon?
    By rbusi2025 in forum BlackBerry Priv
    Last Post: 03-10-2016, 01:44 PM
  5. Is good the battery on Huawei P8 Lite?
    Last Post: 03-09-2016, 06:35 PM
