eddiechi
do you have to enable location with this? That's the current problem I'm having with my Garmin. Its a MM feature that's causing my uproar. I just sync it once a week now which I hate. Can you give me any hints on what apps work with it?! I'm beyond curious. I love my Garmin but I do love the ability of a smartwatch beyond my Garmins basics
Does it affect doze?
The gear "plugin" does show up under "location" but I am not sure why.. it works fine with location off... maybe it is because I have it connected through wifi as well..... as far as apps go I haven't had much time to experiment with many of them..
I have only downloaded different apps for the watch faces and fitness stuff like "map my ride" "ride with gps", "map my fitness" and endomondo and now that I think about it I think the app "ride with gps" is what turned on "location"..... I haven't checked for any new apps in a few weeks..... oh, I also added "gear navigator" app and the uber app recently which also requires location on.... but otherwise s2 works fine with location off.... not sure about possible issues with syncing or anything to do with mobile maps
