jls1986
Re: Which wireless charger?
I just got this charger. When it quick charges it makes a weird noise. It's not loud but it would be annoying being right next to my head when I sleep. Does yours make a sound?
I can recommend this one: 3 Coils Fast Wireless Charger CHOETECH Stadium Qi Wireless Charger Wide Charging Area Wireless Charging Pad
Been testing this now and it supports the Fast Wireless charging found on the S6 edge+, Note5 and the S7 series. Only problem I have had is that it for some reason doesn't work with the samsungs own fast charger. So make sure you have a Qualcomm Quick Charge 2.0 compatible charger to go with this.
