I figure just to place this on a wireless charger at night so I don't have to mess with cables. Since that is the case, fast charging probably doesn't really matter. Is it best to stick with a Samsung charger or do you have other recommendations?
I can recommend this one: 3 Coils Fast Wireless Charger CHOETECH Stadium Qi Wireless Charger Wide Charging Area Wireless Charging Pad
Been testing this now and it supports the Fast Wireless charging found on the S6 edge+, Note5 and the S7 series. Only problem I have had is that it for some reason doesn't work with the samsungs own fast charger. So make sure you have a Qualcomm Quick Charge 2.0 compatible charger to go with this.
I've seen the Samsung Fast Charge Qi Charger on eBay for around $25-35. Is there an issue with these things? The sellers seem alright...I'm not talking about the ridiculously cheap ones from China. Anybody have any luck with these?
The price is little steep but it's a 3coil charger which helps with the placement of the device so that it is not so analysis about it.
Never heard about the Ghost. Any link for it?I love 3 coil chargers. Just plop down and you're good to go. I'm anxiously awaiting the Incipio 15W Ghost though. 15W of powerrrrrrrrrrr (insert Tim Allen here) rrrrrrrrrrrr. Wonder when a 15W stand charger will be out...
Incipio Ghost 15W Qi Fast Wireless Charging Pad - Black :: MobileFun.com
It hasn't launched yet and it is quite expensive.
when i put it in my checkout cart it says it ships march 24
