1. Mobyone01's Avatar
    Is it just me or does anyone else having a problem typing while holding the phone with both hands?? My palms keep touching
    the egdes making me perss Enter or Backspace..... it is really annoying! I don't remember having that problem with my Edge+
    Please share your thoughts.
    03-10-2016 01:46 AM
  2. KimJongOMG's Avatar
    This is the primary reason I've run a case on my S6E and now my S7E. I wish Samsung would've just made the frame a tad thicker so there's more of a gap between the palm and the screen.
    Mobyone01 likes this.
    03-10-2016 01:56 AM
  3. Lobwedgephil's Avatar
    Seems like more of an issue then last years model, more sensitive screen I guess, Either way, like the great leader says, a case helps a bunch.
    KimJongOMG and Mobyone01 like this.
    03-10-2016 01:59 AM
  4. KimJongOMG's Avatar
    Don't just take my word for it; here are some more opinions on the subject:
    http://forums.androidcentral.com/sam...ml#post5042693
    Also, supreme, not great, supreme. Like a pizza. Supreme.
    Lobwedgephil likes this.
    03-10-2016 02:17 AM
  5. NexusGirlX's Avatar
    Yes, get a case and it will help. I haven't had this problem at all since putting mine in a case.
    03-10-2016 02:32 AM
  6. KimJongOMG's Avatar
    See! Another one! And she's a retired mod so you know she doesn't lie unlike most capitalist pigs!
    inffy likes this.
    03-10-2016 02:36 AM
  7. Mobyone01's Avatar
    Thanks everyone.... I do have a case on the handset btw... I guess what I really need to get is a thicker case! So basically you have to choose between functionality and design!!!
    03-10-2016 02:46 AM
  8. dpham00's Avatar
    I don't have a problem but I am using a case
    03-10-2016 05:41 PM
  9. KimJongOMG's Avatar
    Yeah, it's too bad you have to cover up the elegant design of the phone using a case. I rarely drop my phone so I've used my phones without a case until the S6 Edge came along. The screen is the only reason I use one.
    03-10-2016 05:52 PM
  1. I have a Galaxy s7 edge and my screen won't turn off
    Last Post: 09-24-2017, 07:14 AM
  2. How can I get rid of the ads on my home screen permanently
    By John246980 in forum Samsung Galaxy S6
    Last Post: 09-11-2017, 04:02 PM
  3. Screen sensitivity
    By tesladroid in forum Samsung Galaxy S7 edge
    Last Post: 03-13-2016, 09:26 AM
  4. How can I stop my screen from lighting up?
    Last Post: 03-10-2016, 12:07 AM
  5. Lock screen notifications
    By kyleresq in forum Samsung Galaxy S7 edge
    Last Post: 03-09-2016, 07:03 PM
