I trimmed mine a bit and I will be useing it until I can figure out a good screen protector. The stock one isn't terrible.
Same cuts here. I wasn't impressed with the plastic protectors that work on my s6 edge, so I will probably keep this until people can confirm a good fitting tempered glass screen protectorYea, I peeled mine up and cut the home button out and the tab at the top left corner.
I believe it's going to be very difficult to find a working tempered glass for the S7 edge.
I have never seen someone make their own screen protector from the original plastic on the phone. This is funny and yet inspiring.
You don't 'make' anything, you just leave it there. Affects the sensitivity somewhat, but it'll do until mine comes in. It ain't rocket science.
You cannot use the FingerPrint reader if you leave a plastic protector on. I've tried
Nekid feels betterYou can if you trim out the are over the home button. I don't think it's going to last too long though.
When I put a case on it starts peeling up on the one side and by the home button.
