1. wuttqq's Avatar
    Maybe the dumbest question ever, but is there plastic on the camera lens and flash?
    On the s6 there was plastic, and i had to take a knife to remove it, so before doing that again, I want to make sure.
    03-10-2016 01:20 PM
  2. VetteVert's Avatar
    Wasn't on mine.
    03-10-2016 01:23 PM
  3. anon(607340)'s Avatar
    None on mine either
    03-10-2016 01:37 PM
  4. AlphaVictor87's Avatar
    ill add to this, didn't have any on mine.
    03-10-2016 03:46 PM
  5. anon(5630457)'s Avatar
    There wasn't any plastic on my flash, lens, or heartbeat sensor either.
    03-10-2016 03:47 PM
  6. Averix's Avatar
    Just the big plastic sheet on the back is all. Once that's off, no back plastic that I could find.
    03-10-2016 05:02 PM
  7. dpham00's Avatar
    Didn't see any on mine
    03-10-2016 06:24 PM
  8. dhughes's Avatar
    None on my s7 edge. At&t version.
    03-10-2016 07:14 PM
  9. kuhns787's Avatar
    I remember on the S6 Edge+ that there was and it was so hard to see and it almost looks like there could be on this one and if you feel it feels like a film?
    03-20-2016 09:18 PM
  10. PsychDoc's Avatar
    None on mine. Verizon silver.
    Tatt2014 likes this.
    03-20-2016 09:45 PM
  11. FarKeld's Avatar
    There was a film on the flash/HR sensor of my phone (S7)
    I think there is something on the camera too but i'm not sure and i dont want to scrath the camera
    https://drive.google.com/open?id=0B-...FkyazlQQ2x5cW8
    04-22-2016 08:20 AM
  12. chiaph's Avatar
    how did you manage to lift the film off?
    05-24-2016 08:27 AM
  13. danlnyc's Avatar
    There was one on my flash but not the camera. I used a piece of tape and removed it pulling it sideways for the most grip. It came off instantly.
    05-24-2016 04:15 PM
  14. firstnametravis's Avatar
    There is plastic on both the camera lens and the flash. I have the galaxy s7 edge and can confirm this. It's so hard to see it almost looks like it's part of the phone. I used my nails to pull them off. It was tricky but I eventually got it. Makes me wonder how many people out there with the s7 and s7 edge still have the plastic on their camera sensor/flash and don't even know it.
    08-11-2016 02:05 AM
  15. RocketFoot's Avatar
    There was a clear film on my flash that I just took off but it doesn't look like any thing on the camera lens. I tried the tape trick on the lens and nothing came off.
    08-11-2016 07:35 AM
  16. manny_toba's Avatar
    I called the store where I got my phone and they said there was no film, they are wrong. I can confirm there is a plastic film covering the camera lens, it doesn't cover the whole lens though. I used a toothpick and gently raised the film from the center and not the edge of the lens. It does not cover the small center of the lens.
    Hope it helps.
    10-06-2016 06:19 PM
  17. anon(5719825)'s Avatar
    I think there is but I've never been able to peel it off so I've let it on all these months.
    10-07-2016 11:34 AM
  18. Distrack's Avatar
    there was a plastic film over the flash/sensor. Extremely hard to see and to remove.
    01-14-2017 03:06 PM
  19. Messi CRO's Avatar
    Did anyone remove scratches from flashlight?
    Vanishd likes this.
    02-21-2017 02:01 PM
  1. Replies: 3
    Last Post: 04-11-2017, 01:34 PM
  2. Why is my phone changing and skipping songs on its own?
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-11-2016, 04:38 PM
  3. how to increase sound volume on gear s2 on notifcations
    By AC Question in forum Samsung Gear S2
    Last Post: 03-10-2016, 08:54 PM
  4. Replies: 1
    Last Post: 03-10-2016, 03:23 PM
  5. Replies: 1
    Last Post: 03-10-2016, 01:04 PM
