03-31-2016 11:48 AM
171 1234 ...
tools
  1. felloffthetruck's Avatar
    Good luck with that ^^
    03-21-2016 06:11 PM
  2. KimJongOMG's Avatar
    Guys, the Samsung browser is downloadable and I've been using it for a day now. For some reason, it doesn't show up in the Play Store, which is where I downloaded it from, which is weird but I can confirm it's live.
    -- Do a Google search for "Samsung Browser" on your S7/Edge
    -- Click on the Play Store link for the browser
    -- Install
    Adblock Plus is also there for use with the Samsung browser so make sure you grab that too.
    Edit: Seems it's not working for everyone right now. I have been lucky as well as kami. Just remember you have to have the latest OTA update installed and this is only for the Verizon variant.
    03-21-2016 06:20 PM
  3. limitbreak09's Avatar
    -- Install
    Not for me
    -S7Edge
    03-21-2016 06:23 PM
  4. jpdaballa's Avatar
    I'm still getting the this app is not compatible with your device
    03-21-2016 06:23 PM
  5. jpdaballa's Avatar
    Is there a way you can make a back up of the apk and share it with us?
    03-21-2016 06:28 PM
  6. KimJongOMG's Avatar
    Not for me
    -S7Edge
    You two searching for it directly in the Play Store?
    BTW I'm on a Verizon variant.
    03-21-2016 06:29 PM
  7. jpdaballa's Avatar
    I searched through Google, and I am also Verizon variant. Have you done the latest ota?
    03-21-2016 06:30 PM
  8. vdob's Avatar
    The download doesn't work for me either. I searched through a browser and clicked the Play link. It says that it's not compatible with my Verizon S7 Edge.
    03-21-2016 06:32 PM
  9. KimJongOMG's Avatar
    Yes I have. Did it the day it went live. Perhaps that's the difference if you haven't? Guess we'll find out.
    Oh, and make sure the link for the Play Store takes you into the Play Store app and not your browser. I'm not sure if that's clear...
    Hm... Worked perfectly for me. Have you updated your phone?
    03-21-2016 06:33 PM
  10. limitbreak09's Avatar
    i searched it using the stock browser and tried chrome too. After you click the app it will bring you to play store and you will see this
    -S7Edge
    Attached Thumbnails Samsung Internet Browser for Verizon-screenshot_20160321-193220.jpg
    03-21-2016 06:33 PM
  11. felloffthetruck's Avatar
    -- Install
    Me no see? I see the not compatible version.
    03-21-2016 06:34 PM
  12. limitbreak09's Avatar
    Forgot to tell. im.on at&t
    -S7Edge
    03-21-2016 06:35 PM
  13. KimJongOMG's Avatar
    -S7Edge
    Could be the issue. Perhaps AT&T will be compatible with an update?
    Sent from my Chrome™ Samsung S7 Edge SM-935V
    03-21-2016 06:37 PM
  14. kami8586's Avatar
    I! On Verizon too
    S7 Edge Titantium
    vdob likes this.
    03-21-2016 06:40 PM
  15. KimJongOMG's Avatar
    I! On Verizon too
    S7 Edge Titantium
    kami, did you apply the OTA update from Monday or whenever it was?
    03-21-2016 06:42 PM
  16. felloffthetruck's Avatar
    Why does it say not compatible for me? I'm on Verizon and have the latest update.
    03-21-2016 06:42 PM
  17. KimJongOMG's Avatar
    Did you apply the OTA update?
    03-21-2016 06:43 PM
  18. felloffthetruck's Avatar
    Yes.
    03-21-2016 06:46 PM
  19. VetteVert's Avatar
    Same here. Verizon on latest update. No dice.
    03-21-2016 06:47 PM
  20. KimJongOMG's Avatar
    Yes.
    100% sure it's launching into the Play Store app when you click the link for the browser?
    03-21-2016 06:48 PM
  21. felloffthetruck's Avatar
    I think you might have to just hit "Install" from the search and not click the play store link? Is this it?
    I get the same not compatible as above when clicking the play store link.
    03-21-2016 06:49 PM
  22. KimJongOMG's Avatar
    It's certainly worth a shot. I just clicked on the link and went in but crazy phones are crazy and you might have to do it differently.
    03-21-2016 06:51 PM
  23. felloffthetruck's Avatar
    I'm getting the same result either way, not compatible with my device. I don't understand.
    03-21-2016 06:53 PM
  24. jls1986's Avatar
    Still not working for me either.
    03-21-2016 07:04 PM
  25. rflores5432's Avatar
    Nope doesn't work for me either and I have the recent update installed and on Verizon
    03-21-2016 07:05 PM
171 1234 ...
  1. Free battery and charging cradle from LG for G5
    By tourbound129 in forum LG G5
    Last Post: 03-10-2016, 04:50 PM
  2. Samsung Galaxy S3 - I want to change from T-Mobile to Verizon
    By One Pheather in forum Samsung Galaxy S3
    Last Post: 03-10-2016, 04:27 PM
  3. Persistent notification sounds on Samsung S6!
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-10-2016, 04:24 PM
  4. Why does my samsung note 4 have such a bad battery life
    By riddlemoss3196 in forum Samsung Galaxy Note 4
    Last Post: 03-10-2016, 04:20 PM
  5. Is it safe to disable all the Verizon apps?
    By felloffthetruck in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 03:05 PM
