03-31-2016 11:48 AM
171 ... 4567
tools
  1. felloffthetruck's Avatar
    03-26-2016 10:46 AM
  2. xocomaox's Avatar
    I installed a modded APK from XDA since the store was not allowing me to install. Works great.
    03-26-2016 11:24 AM
  3. areyes163's Avatar
    Still doesn't work for me. I got the update last night as well but when I go to the app page it says incompatible.
    03-26-2016 02:39 PM
  4. felloffthetruck's Avatar
    Same here, still not compatible. I'll pass on the APK though.
    03-26-2016 02:45 PM
  5. BIG CAT 7's Avatar
    I haven't had much luck either. I have just been using the XDA APK for the past handful of days with no issues. Just use that until it is finally live in the Play Store.
    03-26-2016 06:46 PM
  6. zainsikander32's Avatar
    I used logging in from a different account and then was able to download it on 3 different Verizon phones using Opera mini as a browser and downloading it through the Web play store.
    03-27-2016 12:26 AM
  7. zainsikander32's Avatar
    But now that since some of you have it. Which one do you prefer or think is faster? Chrome or Samsung Internet? I miss all my auto fill data because I've been using Chrome for years though. Let me know if someone finds a way to sync the data through.
    03-27-2016 12:27 AM
  8. SprintFun's Avatar
    Ad block + speed > autofill.
    I feel your pain though
    03-27-2016 08:33 AM
  9. sangs's Avatar
    Question - could I save my Chrome bookmarks as an HTML file to my SD card then import them into the Samsung browser?
    03-27-2016 08:47 AM
  10. ctk4949's Avatar
    03-27-2016 12:41 PM
  11. simaand's Avatar
    Got it to work on my Verizon S7 Edge, Just googled Samsung Internet, Found the Playstore link and installed directly from the google play store.
    03-27-2016 02:23 PM
  12. puddlejumper32's Avatar
    I've used it on my Samsung Gear VR and I like it.
    03-27-2016 02:47 PM
  13. vdob's Avatar
    All of my Chrome bookmarks synced to the Samsung browser. Just make sure "sync internet" is checked off in the Samsung Account settings.
    03-27-2016 03:04 PM
  14. ClintRo's Avatar
    03-27-2016 09:47 PM
  15. greenplum's Avatar
    Awesome, thanks
    03-27-2016 10:20 PM
  16. wxman2003's Avatar
    Was able to download! Verizon's easter egg.
    03-27-2016 10:27 PM
  17. MauJac's Avatar
    A few moments ago I donwloaded the Samsung Internet app on my SGS4 Verizon and after open it took me to a Yahoo finance page then I tapped back and took me to tigerdirect site, after tapping on browser box for to enter a new web site address popped up a quick access list of web sites like Google, AOL mobile, Insider`s, Dictionary, Accuweather, Yelp, ESPN, YouTube, Yahoo. You can edit quick access. I typed androidcentral.com and reached it fast. I will continue trying it to see how it works finally.
    I suggest you to make a try too.
    03-27-2016 11:26 PM
  18. dpham00's Avatar
    I am pretty sure my Note 5 was compatible...LOL not 100% sure tho.
    It has always been on the note line because some s pen features can be used with it.
    03-27-2016 11:32 PM
  19. RockyMin's Avatar
    I had loaded the apk on my phone, and now when I got Samsung Internet I am getting the buttons for uninstall and open. So I guess it's now compatible with my phone too, lol.
    03-28-2016 03:55 AM
  20. Mojave's Avatar
    I'm on Verizon also. I have the Galaxy S5 with OS 5.0. Found it in the Google Play Store but it said it is not compatible with my phone. But if you read about it.....it states......
    "The 4th version of Samsung Internet brings lots of new and exciting features.
    This update is available for Galaxy S7 Edge, S7, Note5, S6 Edge+, S6 Edge, S6, S6 Active, Note4, S5, S5 Neo, S5 Active, S5 Sports, S5 LTE A, Note3, S4, S4 Duos, S4 Active, S4 LTE A, A7, A8, A5x, A7x, and A9x with Android 5.0 and above."
    The S5 is listed! This really sucks!!
    EDIT: I just signed in with another account on my S5 for the Google Play Store and NOW I was able to download it. Weird.....really weird. Will check the browser out and see how I like it.
    03-28-2016 06:20 AM
  21. sangs's Avatar
    It is. Doesn't work for me, bummer. Discovered a work around at least by opening the HTML file and saving it to the Quick Access page. Better than nothing.
    03-28-2016 06:30 AM
  22. DFranch's Avatar
    Don't know what I did, but I was finally able to download it last night. First it wasn't supported, then it was, weird! Anyway, I can't believe how fast the browser is. It blows chrome and firefox out of the water.
    felloffthetruck likes this.
    03-28-2016 07:57 AM
  23. Channan's Avatar
    Anyone who has both, how is the battery life using the Samsung browser compared to Chrome?
    03-28-2016 08:12 AM
  24. Jeff Saul's Avatar
    I was able to download and install it on S6 no problem from the link posted.
    Can someone tell me what this app does that Chrome doesn't? Is Samsung Internet better?
    03-28-2016 08:20 AM
  25. demarco5's Avatar
    battery use way higher using samsung than chrome, ill stick with chrome
    03-28-2016 08:25 AM
171 ... 4567
  1. Free battery and charging cradle from LG for G5
    By tourbound129 in forum LG G5
    Last Post: 03-10-2016, 04:50 PM
  2. Samsung Galaxy S3 - I want to change from T-Mobile to Verizon
    By One Pheather in forum Samsung Galaxy S3
    Last Post: 03-10-2016, 04:27 PM
  3. Persistent notification sounds on Samsung S6!
    By AC Question in forum Samsung Galaxy S6
    Last Post: 03-10-2016, 04:24 PM
  4. Why does my samsung note 4 have such a bad battery life
    By riddlemoss3196 in forum Samsung Galaxy Note 4
    Last Post: 03-10-2016, 04:20 PM
  5. Is it safe to disable all the Verizon apps?
    By felloffthetruck in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 03:05 PM
