felloffthetruck
Trusted Member
- Mar 31, 2013
- 8,616
- 22
- 38
Why does it say not compatible for me? I'm on Verizon and have the latest update.
Yes.
I think you might have to just hit "Install" from the search and not click the play store link? Is this it?
I get the same not compatible as above when clicking the play store link.
kami, did you apply the OTA update from Monday or whenever it was?
I'm getting the same result either way, not compatible with my device. I don't understand.
Still not working for me either.
Nope doesn't work for me either and I have the recent update installed and on Verizon
Yep sure did. There's so many ad blockers which is the right one though.
S7 Edge Titantium
I have done the latest ota and its not allowing me. I'll try resetting my phone and messing around with a few settings like setting the clock a day ahead and such
I asked Samsung at their customer care site. They wrote me back and basically said the same thing as the Verizon guy told the OP. Available end of March.
This is what I get
What is that lightning bolt next to the 4g signal?
i searched it using the stock browser and tried chrome too. After you click the app it will bring you to play store and you will see this
-S7Edge
