Samsung Internet Browser for Verizon
I think you might have to just hit "Install" from the search and not click the play store link? Is this it?
I get the same not compatible as above when clicking the play store link.
It's certainly worth a shot. I just clicked on the link and went in but crazy phones are crazy and you might have to do it differently.
Nope doesn't work for me either and I have the recent update installed and on Verizon
This is what I get
I have done the latest ota and its not allowing me. I'll try resetting my phone and messing around with a few settings like setting the clock a day ahead and such
I asked Samsung at their customer care site. They wrote me back and basically said the same thing as the Verizon guy told the OP. Available end of March.
I'm getting the same result either way, not compatible with my device. I don't understand.
Still not working for me either.
They might be gradually rolling this out as Samsung had a HUGE issue with the browser not working at all because of the update. Me and kami may have just gotten lucky and live in an area that's allowing the browser to be installed.
Yep sure did. There's so many ad blockers which is the right one though.
S7 Edge Titantium
I use Adblock Plus by Eyeo GmbH. It says it right there in the title it's for the Samsung browser. Adblock Plus (Samsung Browser).
This is what I get
Give it a few days and see what happens. Could be a gradual roll out. Just remember the browser is downloadable and fully functional for some folks so it's most likely just a matter of time.
What is that lightning bolt next to the 4g signal?
Download booster. Uses both wifi and LTE to download large files quickly. Fast way to destroy your data usage limit if you're not on a grandfathered unlimited data plan.
i searched it using the stock browser and tried chrome too. After you click the app it will bring you to play store and you will see this
-S7Edge
Exactly what I get. Though I have to say, after switching from Chrome to the speedy RS Browser, I'm not as annoyed about this as I was before.
I'm using it on my phone right now. My guess is that it is slowly starting to work. I got to it through searching on the chrome browser.
Tried to install it on my Verizon S7 Edge but the store tells me that my device isn't compatible with this version.
albertowalish
