04-23-2016 07:46 PM
28 12
tools
  1. charlieferro29's Avatar
    I am having to manually sync to get my emails. I read some other phones were affected but I cannot seem to find anything that says this is an issue with the S7 Edge...
    03-10-2016 04:32 PM
  2. dpham00's Avatar
    Which app are you using? I am using both the stock Samsung and Gmail apps and both sync fine. For the Samsung app, you can set the poll interval
    03-10-2016 04:35 PM
  3. charlieferro29's Avatar
    I am using the Gmail app. To test it now again, I sent an email to myself from another email accout to my Gmail address and it arrived right away. However, my Edge still shows nothing and it has been 10 minutes...
    03-10-2016 04:40 PM
  4. felloffthetruck's Avatar
    A lot of galaxy phone have problems with the "Push" notifications. Had this problem with the S6 and Note 5.
    Please post if you find a solution.
    03-10-2016 05:11 PM
  5. sfldg's Avatar
    this is a google issue not phone related. they were supposed to release a fix server side that would fix it. its been a couple months and its random really, i still have to manually refresh on my nexus6
    03-10-2016 05:13 PM
  6. Dukins's Avatar
    I am having this problem as well. I may have to switch to a different email client if this continues. I use Gmail for business. And it's bad business to leave my clients hanging for hours on end.
    03-24-2016 06:09 AM
  7. MartinMPL's Avatar
    Yeah, I don't think it is necessarily the phone. It was happening quite frequently on my Nexus 5x until I swapped it for the Edge.
    03-24-2016 06:51 AM
  8. ktabel01's Avatar
    yeah having this as well and don't think it's a phone issue. See it on my work iphone as well
    03-24-2016 09:43 AM
  9. Adiliyo's Avatar
    it's def a server side issue for gmail, they've been working on it, but a 100% working solution hasn't been found yet
    03-24-2016 12:25 PM
  10. Almeuit's Avatar
    I use Gmail and it pushes emails when I get them for other things / from the forums.
    03-24-2016 12:28 PM
  11. Dhawk1202's Avatar
    Android police posted about this today....
    Gmail's Synchronization Bug Is Far From Resolved: Users Still Reporting Issues Despite Promised Fix
    http://www.androidpolice.com/2016/03...-promised-fix/
    03-24-2016 12:52 PM
  12. Adiliyo's Avatar
    i think this is why it's been taking google so long to fix it, it's not a consistent bug (i personally have no gmail issues, but my friend does, and he has had them on a G4, a V10, and now his S7E) and somewhat hard to consistently replicate what triggers it for some people.
    03-24-2016 02:59 PM
  13. sfla99's Avatar
    Just started having this issue, I was thinking, man I have not received any email lately from Gmail, did a manual pull to refresh them boom, 8-10 emails come down.
    Not good. Didn't had this issue on last phone IP6S+ but do now.
    Not sure if it's edge related but I am now also getting 25+ text messages a day from AT&T but that's a whole other issue.
    03-25-2016 12:02 AM
  14. Nkky7's Avatar
    I kinda like that i dont get the "push". Gmails. I just refresh it when i have to..
    03-25-2016 01:37 AM
  15. Andy Adler's Avatar
    The only time I have a similar issue is when I check my Gmail first thing in the morning, and for whatever reason the last mails pushed came in around 3 a.m., so I have to manually refresh to get the remainder. Push works fine after that. It was the same on my previous phone, so it doesn't appear to be S7/S7E-specific.
    03-25-2016 08:10 AM
  16. recDNA's Avatar
    I set up gmail on my samsung stock email app now it always comes through immediately. It's something to do with the gmail app. If it is a server side issue as many have said why do I get gmail immediately pushed through samsung app?
    03-25-2016 10:07 AM
  17. Adiliyo's Avatar
    it seems to be an issue with the way the app interfaces with their servers. so it's an app/server issue, most of the time for users who are having the issue, changing to a different app usually works.
    03-25-2016 10:53 AM
  18. anon(5630457)'s Avatar
    Yep. I don't get any notifications for a lot of emails. I'm using Inbox with push turned on.
    03-25-2016 11:21 AM
  19. eyeowanc's Avatar
    I'm having the same issue with not receiving Gmail notifications. Sometimes it works, but often it doesn't, especially first thing in the morning. I didn't have this issue on my S6 Edge.
    03-25-2016 11:43 AM
  20. GoreJak's Avatar
    My both S7 Edge have the same syncing issues with Gmail, contacts, calendar, Facebook and other.... So I turned OFF the optimize battery usage individually. Those apps are syncing fine now.
    03-30-2016 09:08 AM
  21. Blacklance's Avatar
    I think we may have a winner here! Seem's to have worked for me!
    03-31-2016 12:08 PM
  22. mookie1028's Avatar
    if power saving mode is on then gmail will not work try using my mail it will work with power saving mode on and off
    04-14-2016 10:51 AM
  23. anon(5719825)'s Avatar
    I have been having a problem with Gmail as well as contacts syncing between different phones using the same Gmail account. Usually if I add a contact on one phone, it will sync to the other three with no problems. That hasn't been working in over a month.
    04-14-2016 12:25 PM
  24. GoreJak's Avatar
    Did you try my method? Described as above.....
    04-14-2016 03:56 PM
  25. anon(5719825)'s Avatar
    Do you mean turning off the switch at the top of the app optimization screen?
    04-15-2016 12:29 AM
28 12
  1. My Gmail will not sync on my Galaxy S7
    Last Post: 04-22-2018, 03:31 PM
  2. Replies: 1
    Last Post: 03-11-2016, 02:30 PM
  3. home button issue
    By Maknora in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 05:24 PM
  4. Wifi issues
    By mikecomp93 in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 04:39 PM
  5. Why is the ring tone suddenly turned off
    Last Post: 03-10-2016, 03:54 PM
