1. obana1990's Avatar
    Just received it today.
    I moved contacts, app to the S7 edge and then I realize I haven't setup the finger prints screen lock yet as I skip it on the initial setup.
    I then follow the instruction and finish the setup but then I realize I still able to swipe to unlock the phone and finger print won't work.
    I tried other security setting like PIN/Swipe/Password.
    None of them work.
    Restart the device, factory reset all doesn't work at all.
    The phone even hangs for a bit...
    I'm so excited that I'm able to get my hand on it today but I'm really frustrated at this point as I already spent 3 hours+ to figure what the hell is wrong with the device? Is it a faulty device or Samsung is actually letting me down once again?
    My phone was pre-ordered from AT&T.
    I'm been waiting in the technical support queue for almost an hour.
    Samsung technical support is not available as well.
    Could anyone please advise?
    03-10-2016 10:20 PM
  2. wxman2003's Avatar
    03-10-2016 10:24 PM
  3. Adranalyne's Avatar
    Lock screen and security>Secure Lock settings>Secured Lock time>Instantly when power key.
    Should fix it.
    alhc78 likes this.
    03-10-2016 10:27 PM
  4. obana1990's Avatar
    I did the same thing exactly 4-5 times...doesn't work.
    In fact it work once and then it fails again.
    03-10-2016 10:31 PM
  5. KimJongOMG's Avatar
    So what is the "Lock automatically" setting set to?
    03-10-2016 10:45 PM
  6. streetkilln's Avatar
    This happened to me, I set up fingerprint and pattern yet it still unlocked without the need for them.
    What I did solved the issue.
    Went back to the setting removed me fingerprints and my pattern lock. Then restarted my phone and went back set up fingerprint prints then other lock option.
    03-11-2016 03:04 AM
  1. Any one regret not getting the Edge variant?
    By sfla99 in forum Samsung Galaxy S7
    Last Post: 03-12-2016, 10:10 PM
  2. Edge Panel - Broken or oversight?
    By LSG67 in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 09:35 AM
  3. MMS photos missing after transfer to S7
    By jaxsta in forum Samsung Galaxy S7
    Last Post: 03-11-2016, 10:49 PM
  4. Replies: 3
    Last Post: 03-10-2016, 09:26 PM
  5. moving photos with galaxy s7 edge.
    By Constance Barrett in forum Samsung Galaxy S7 edge
    Last Post: 03-10-2016, 09:18 PM
