1. chanmanx2k's Avatar
    I had a Galaxy S6 and the stock Samsung player was the only audio player that worked well with my 2014 BMW. Default Samsung app would sync playlist information to my car over bluetooth. I was able to navigate through my playlists on screen and my HUD. Wondering if any of you guys have tried any other options to get playlist support back now that the default samsung music app is gone
    03-10-2016 11:37 PM
  2. chanmanx2k's Avatar
    Nevermind, I figured it out. I have verizon gs7. You need to enable the widget called samsung essentials and access the samsung appstore from the widget
    03-10-2016 11:56 PM
  3. KimJongOMG's Avatar
    You can also just head into the Galaxy Apps store and download it without using that widget. Glad you got it figured out though.
    03-11-2016 12:17 AM
  1. Gear S Watch Not 100% Compatible with Marshmallow
    By NexusGirlX in forum Samsung Galaxy S7 edge
    Last Post: 10-06-2016, 06:56 AM
  2. what protective cases are compatible
    By AC Question in forum Samsung Galaxy S6 active
    Last Post: 03-11-2016, 10:08 AM
  3. what protective cases are compatible
    Last Post: 03-10-2016, 06:53 PM
  4. How do I check app compatibility with a potential new device?
    By Warwick Anderson in forum General Help and How To
    Last Post: 03-09-2016, 09:10 PM
  5. Nexus 6P and 2011 BMW 5 series
    By ChristianTW1 in forum Nexus 6P
    Last Post: 03-09-2016, 02:30 PM
