so, I received my S7 Edge on Wednesday, and was really excited to use this device. I am an iPhone 6s Plus user and was hoping to find a device with the same screen size that was a little easier to manage in the hand. I'm very disappointed in the device. I have run into a consistent issue where I can not download apps from the Play Store. I will start the download process and the app just scrolls the progress line in the notifications pane, as well as the Play Store app, and never moves past "Downloading....". I've factory reset multiple times, gone through a process of deleting data from the Play Store services, but at some point within 10 app downloads the problem resurfaces and cannot be bypassed until you factory reset. I'm wondering if the device is just faulty. I'm going to return it today and potentially get another handset to play with over the weekend, but yeah, currently the device is not usable, has been reset and put back in the box for return. What a shame.
It also runs VERY hot, seems to have a difficult time with navigation or touch screen elements that live near the screen edge. Overall, I feel that I either have a faulty device, or too high of expectations coming from the 6s Plus.
