S7 Edge WiFi dropping?
MartinMPL
378
So I think I have my first bug/fault.
The WiFi appears to be dropping and reconnecting momentarily. When browsing I barely notice but I do see the "toast" pop up with the WiFi name and connected occasionally.
However I've started playing Agar.IO and I keep getting lost connection messages and get booted out (annoying when I'm massive!). Has anyone else seen this or know a possible solution? Thanks.
anon(238680)
4,839
13
I have seen much better signal strength on my S7e, on both 2.4 and 5Gz than my previous Galaxy. No dropping at all. Do you have a wifi analyzer app on your phone?
src1425
80
I've seen the same thing occur, even when the wifi signal is strong. It's not frequent, but it's happened several times today.
MartinMPL
378
Yeah, Smart WiFi is off, and WiFi is also set to always on.
I'll forget the network and start again.
I had a faulty S6 Edge that did this but cell radios were the priority on that one so I didn't really take note...
zipro
863
Everyone who's reporting WiFi issues: can you please include the make and model of your WiFi router as well? WiFi incompatibilities are just as often caused by the AP.
educationalco22
