03-18-2016 05:36 PM
32 12
tools
  1. src1425's Avatar
    I continue to have intermittent drops both at home on my Verizon Fios router and on my work's corporate wifi network. It's not frequent and only momentary, but it's a little annoying.
    03-16-2016 06:03 AM
  2. MartinMPL's Avatar
    Has anyone committed to sending their device back to Samsung?
    Mine is supposed to be collected tomorrow but I'm thinking again since they don't replace before they assess the device. I could be without it for a week...
    03-16-2016 06:27 AM
  3. src1425's Avatar
    Actually, my device is going back for an unrelated issue, as it wouldn't mute, so they're replacing it after they couldn't figure out in the store how to fix it either. Thought it may have been an errant setting, but putting the phone on vibrate or mute simply lowered the volume instead of completely turning it off. New phone isn't expected to ship until 3/31, although they said in the store "it may be earlier". Will be interesting to see if the new phone has wifi problems as well. Will report back if it does, but it might not be for a couple of weeks.
    03-16-2016 07:26 AM
  4. Rumblee1's Avatar
    Thats good info if, being a regular lay person, I knew how to do it. I have a comcast router.
    03-18-2016 01:37 PM
  5. MartinMPL's Avatar
    Decided to cancel the return. I can still do it anytime. There's no benefit in returning within 14 days (unless you want your money back) since they don't straight swap the device. Poor in my opinion, should handle RMAs like Google.
    03-18-2016 01:41 PM
  6. MartinMPL's Avatar
    So, I'm no expert on WiFi - which is an understatement, I know nothing...
    My S7e always seems to be connected to one of the weak channels from my router (nearly always Channel 11). There are two Channels which are always strong in my house (6&14) but the phone never connects to these.
    Is the S7 Edge not set to automatically connect to strong WiFi signals? Is there anything I can do? Is this related to the IPV4 advice from earlier..?
    03-18-2016 03:56 PM
  7. Almeuit's Avatar
    Usually your router controls the channel the wifi is using.
    03-18-2016 05:36 PM
32 12
  1. Where can I find WiFi Mac address?
    By PsychDoc in forum Samsung Galaxy S7 edge
    Last Post: 04-17-2016, 02:13 PM
  2. [App][1.4.2.3] WiFi Automatic
    By cat cheerful in forum Android App Inventor
    Last Post: 03-19-2016, 07:41 AM
  3. Verizon , Unlimited data, FoxFi working on S7 Edge?
    By Jon1029 in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 01:06 AM
  4. S7 Edge App Store Issues
    By JamesCinAustin in forum Samsung Galaxy S7 edge
    Last Post: 03-11-2016, 12:25 PM
  5. G4 on 6.0 won't sign into wifi hotspot
    By vag65 in forum LG G4
    Last Post: 03-11-2016, 09:45 AM
