03-18-2016 06:36 PM
32 12
tools
  1. MartinMPL's Avatar
    So I think I have my first bug/fault.
    The WiFi appears to be dropping and reconnecting momentarily. When browsing I barely notice but I do see the "toast" pop up with the WiFi name and connected occasionally.
    However I've started playing Agar.IO and I keep getting lost connection messages and get booted out (annoying when I'm massive!). Has anyone else seen this or know a possible solution? Thanks.
    03-11-2016 11:54 AM
  2. dpham00's Avatar
    do you have wifi problems with your other devices?
    03-11-2016 12:37 PM
  3. MartinMPL's Avatar
    No, all good
    03-11-2016 12:38 PM
  4. PJRed2008's Avatar
    I have seen much better signal strength on my S7e, on both 2.4 and 5Gz than my previous Galaxy. No dropping at all. Do you have a wifi analyzer app on your phone?
    03-11-2016 12:58 PM
  5. src1425's Avatar
    I've seen the same thing occur, even when the wifi signal is strong. It's not frequent, but it's happened several times today.
    03-11-2016 01:09 PM
  6. Maknora's Avatar
    make sure smart WiFi is off
    03-11-2016 01:14 PM
  7. src1425's Avatar
    It's off.
    03-11-2016 01:20 PM
  8. MartinMPL's Avatar
    Yeah, Smart WiFi is off, and WiFi is also set to always on.
    I'll forget the network and start again.
    I had a faulty S6 Edge that did this but cell radios were the priority on that one so I didn't really take note...
    03-11-2016 01:22 PM
  9. MartinMPL's Avatar
    Is there a particular recommendation for a WiFi analyzer?
    03-11-2016 01:22 PM
  10. PJRed2008's Avatar
    Netgear has a very good one in the Play store. I also use Wifi Analyzer.
    03-11-2016 02:01 PM
  11. MartinMPL's Avatar
    Thanks.
    What about you SRC? Any luck?
    03-11-2016 05:55 PM
  12. Dubss's Avatar
    Check your firmware on The router
    03-11-2016 07:55 PM
  13. zipro's Avatar
    Everyone who's reporting WiFi issues: can you please include the make and model of your WiFi router as well? WiFi incompatibilities are just as often caused by the AP.
    03-12-2016 12:38 AM
  14. MartinMPL's Avatar
    Mine is a BT Home Hub 3...
    03-12-2016 02:30 AM
  15. zipro's Avatar
    The B&B we stayed in a few weeks back had one of those - I had to help the owner reboot it several times because it kept crashing. But when it worked, it was fast :-) Didn't have a Samsung phone then though.
    03-12-2016 07:06 AM
  16. src1425's Avatar
    Thanks.
    Hasn't happened again (that I've noticed) since I posted, but will keep an eye on it and report back.
    03-12-2016 08:32 AM
  17. MartinMPL's Avatar
    Mine continues to drop. Did it on a friend's router too (different model BT) so looks like a call to Samsung next week.
    03-13-2016 07:26 AM
  18. erasat's Avatar
    Check this thread I created earlier and see if it helps you.
    http://forums.androidcentral.com/sam...ml#post5056269
    MartinMPL likes this.
    03-13-2016 10:22 AM
  19. Almeuit's Avatar
    No drops for me so far. It's been running strong. Do you notice drops on other networks?
    03-13-2016 11:20 AM
  20. MartinMPL's Avatar
    Yeah, like I said it appeared to disconnect at a friend's house this weekend. Will try the force IPV4 thing...
    03-13-2016 01:37 PM
  21. Lucy1376's Avatar
    Got to be a Samsung issue. I have found no matter what WIFI your on, turning on Bluetooth almost kills,slows down wifi
    03-13-2016 02:28 PM
  22. PJRed2008's Avatar
    Read your post, turned on bluetooth on the phone and both 2.4 and 5Gz are still humming along the same. Signal strength is still excellent on both (my router is in the basement) and I can see no speed difference with internet access.
    03-13-2016 02:49 PM
  23. Venkatesh Pattamatta's Avatar
    Well I use HTC M7 and D-Link DIR 816 router and I have the same problem, it happens everyday. May or may not be related to s7e
    03-16-2016 05:41 AM
  24. ZMc1834's Avatar
    I'm assuming mine drops intermittently as well, as I will get new notifications that I'm connected to WiFi from time to time.
    ASUS RT-N66U
    03-16-2016 06:06 AM
  25. vixen80's Avatar
    Same here. Very frustrating. Smart switch off, forced stop on blue tooth share, restarted router. Still momentarily drops signal sometimes for a couple of seconds; Sometimes I have to force it to re connect. I have a BT hub 3.
    How do I change to ipv4 I can't find it in the admin pages of my router
    03-16-2016 06:19 AM
32 12
  1. Where can I find WiFi Mac address?
    By PsychDoc in forum Samsung Galaxy S7 edge
    Last Post: 04-17-2016, 03:13 PM
  2. [App][1.4.2.3] WiFi Automatic
    By cat cheerful in forum Android App Inventor
    Last Post: 03-19-2016, 08:41 AM
  3. Verizon , Unlimited data, FoxFi working on S7 Edge?
    By Jon1029 in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 02:06 AM
  4. S7 Edge App Store Issues
    By JamesCinAustin in forum Samsung Galaxy S7 edge
    Last Post: 03-11-2016, 01:25 PM
  5. G4 on 6.0 won't sign into wifi hotspot
    By vag65 in forum LG G4
    Last Post: 03-11-2016, 10:45 AM
