Galaxy Note 10 Deal: BOGO at Verizon!
05-05-2017 04:54 PM
1,609 ... 34567 ...
tools
  1. fonefanatic's Avatar
    I got the 30% off coupon too
    03-12-2016 09:43 PM
  2. MizWylie's Avatar
    I don't know what to buy with the 30% off coupon. Hm.... What are you looking at to pick up?
    Not sure yet. Haven't logged onto the website. Took my single rear end to Deadpool again rather than look. I saw the onyx Galaxy S7 Edge on a gigantic screen though.
    Posted from the S7E Chrome™ on Big Red
    03-12-2016 09:51 PM
  3. ZMc1834's Avatar
    I have tried Verzion Message+ too. The only issue I have with it, is it gives me 3 identical numbers for all of my contacts. I have checked my google messenger app, and the Samsung app, and they do not have multiple identical entries for every person.
    Glad I'm not the only one, I actually get 4 duplicates per contact.
    03-12-2016 10:14 PM
  4. MizWylie's Avatar
    Just have to be better than everyone else with this issue! Lol
    03-12-2016 10:20 PM
  5. ZMc1834's Avatar
    Ha! Yeah I always try to go big or go home.
    03-12-2016 10:24 PM
  6. sumner929's Avatar
    I got the garbage 30% off too. Dumb. They need to bring back the Samsung Pay promo for the free wireless charger.
    keri2000 likes this.
    03-12-2016 10:32 PM
  7. andrew_ackley's Avatar
    I know my old phone used it to scan in at the gym.
    03-12-2016 11:09 PM
  8. GinjaNinja917's Avatar
    I've got the Note Edge. When my phone is plugged in, it shows a constant notification in the drawer that it's fast charging. Does Marshmallow still do this on the S7 edge?
    I know I'm definitely in first world problems territory, but it just bugs me to no end.
    03-12-2016 11:52 PM
  9. bsteppuhn's Avatar
    Yes but I believe I seen somewhere you can turn it off
    I looked around and I don't see it sorry
    03-13-2016 07:50 AM
  10. ZMc1834's Avatar
    I only got the 30% as well.
    03-13-2016 08:53 AM
  11. eddiechi's Avatar
    That is odd, I received the 30% as well, it was in the same email as the free 32gb micro card from samsung... but when I click on the code to redeem it it does not work on any item.....
    03-13-2016 12:52 PM
  12. bsteppuhn's Avatar
    Any of these I can disable? I got all the ones I knew. this ones were labeled pink still. I'm new to the Samsung line I just don't want to mess anything up.
    Basic Daydreams
    BBC agent
    Beacon Manager
    Chocoeukor
    cooleukor
    drive test
    device keystring
    foundation
    galaxy essentials widget
    ims settings
    keychain
    photoscreensaversor
    samsugn galaxy updates
    sapamonitor
    smartswitch
    support and protection(vzw)
    03-13-2016 01:03 PM
  13. KimJongOMG's Avatar
    Basic Daydreams
    BBC agent
    Beacon Manager
    Chocoeukor
    cooleukor
    drive test
    device keystring
    foundation
    ims settings
    keychain
    photoscreensaversor
    sapamonitor
    smartswitch
    I'd turn the galaxy updates back on if you're using stock apps. The rest are fine to leave off.
    03-13-2016 02:02 PM
  14. bsteppuhn's Avatar
    I haven't turned these off yet. But thanks. These were my last to be narrowed down. I managed all the others that I knew I could turn off
    03-13-2016 02:58 PM
  15. bsteppuhn's Avatar
    Does that look alright? I've been all about Motorola the past decade. Never samsung.
    03-13-2016 03:05 PM
  16. KimJongOMG's Avatar
    Too tiny, can't read.
    03-13-2016 03:08 PM
  17. MizWylie's Avatar
    After pulling out my microscope, yes....>.>
    03-13-2016 03:18 PM
  18. bsteppuhn's Avatar
    Lol thanks! I can't wait to see what you battery life is like at home! I have the next two off. I use my phone way more at work! I have a feeling it will be dozing a lot during the day!
    03-13-2016 03:23 PM
  19. bsteppuhn's Avatar
    Now if only I can get my Garmin to correctly connect with it. It'd be best phone ever! Side note I've contacted Garmin to see if it's a software issue on their side that's not up to date first hopefully they email me back this week
    03-13-2016 03:25 PM
  20. metz65's Avatar
    I just realized that there is no Verizon branding on the front.
    03-13-2016 04:08 PM
  21. bsteppuhn's Avatar
    It's nice
    03-13-2016 04:33 PM
  22. bsteppuhn's Avatar
    I have only got 4g once and that was start up. I'm rocking 1x right now what gives?
    impster64 likes this.
    03-13-2016 08:39 PM
  23. clintw22's Avatar
    Not for sure but try going to settings/mobile networks/network mode and switch it to LTE/CDMA. I always switch it off global cause people were saying it helped battery life.
    03-13-2016 08:51 PM
  24. ClintRo's Avatar
    I have been in 4G since I got it pretty much.
    03-13-2016 08:54 PM
  25. ClintRo's Avatar
    You can either reboot or cycle the data toggle.
    03-13-2016 09:00 PM
1,609 ... 34567 ...
  1. Intermittent wifi on Verizon G4 MM
    By GTS21 in forum LG G4
    Last Post: 03-13-2016, 05:45 PM
  2. Why is my phone stuck in factory mode? (Samsung galaxy s5)
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-11-2016, 11:01 PM
  3. Replies: 2
    Last Post: 03-11-2016, 10:54 PM
  4. How long do I need to charge my samsung galaxy J5?
    By AC Question in forum Samsung Galaxy J Series
    Last Post: 03-11-2016, 10:52 PM
  5. Verizon S7 $260 AR on DPP with new line
    By dpham00 in forum Samsung Galaxy S7
    Last Post: 03-11-2016, 03:13 PM
