05-05-2017 04:54 PM
1,609 ... 636465
tools
  1. Dngrsone's Avatar
    I really wish there was a dark theme for the S7E that got rid of all the white in the settings, email, etc...
    05-05-2017 02:59 PM
  2. LineKill's Avatar
    Try Material Dark or SD Black.
    05-05-2017 03:20 PM
  3. Dngrsone's Avatar
    I've tried Material Dark, had no effect. I will look at SD Black, thanks.
    05-05-2017 03:28 PM
  4. LineKill's Avatar
    It should change it, but it will only change it in stock apps, no 3rd party apps. Also through out the system UI.
    05-05-2017 03:34 PM
  5. Dngrsone's Avatar
    Meh, when looking at the email inbox, it's all white.
    Am I really asking for that much? I can't be the only person who doesn't want all this whiteness/brightness on their phone. 😦
    05-05-2017 04:16 PM
  6. LineKill's Avatar
    I'm sorry, that is as dark as it gets. I believe all the white is probably the number one complaint overall.
    It can be pretty hard on the eyes😨 I am using a dark theme and I am OK for now. Hopefully that will add a dark/light toggle in the futureツ
    05-05-2017 04:25 PM
  7. Dngrsone's Avatar
    ...so, is the email app in a (Verizon) Samsung phone considered stock or third-party?
    05-05-2017 04:33 PM
  8. LineKill's Avatar
    It is stock, I don't use it myself but I loaded it up and to my surprise the inbox and everything is white with a little black. I use stock for everything else and they are all black with a little white. Makes no sense!
    Dngrsone likes this.
    05-05-2017 04:48 PM
  9. Dngrsone's Avatar
    Well, I'll just have to find an alternative app that can handle Outlook Enterprise...
    LineKill likes this.
    05-05-2017 04:54 PM
1,609 ... 636465
  1. Intermittent wifi on Verizon G4 MM
    By GTS21 in forum LG G4
    Last Post: 03-13-2016, 05:45 PM
  2. Why is my phone stuck in factory mode? (Samsung galaxy s5)
    By AC Question in forum Samsung Galaxy S5
    Last Post: 03-11-2016, 11:01 PM
  3. Replies: 2
    Last Post: 03-11-2016, 10:54 PM
  4. How long do I need to charge my samsung galaxy J5?
    By AC Question in forum Samsung Galaxy J Series
    Last Post: 03-11-2016, 10:52 PM
  5. Verizon S7 $260 AR on DPP with new line
    By dpham00 in forum Samsung Galaxy S7
    Last Post: 03-11-2016, 03:13 PM
