Lepa79
I believe so yes.Does Verizon charge updates against our monthly data allotment?
Yes they do. Try to do it over WiFi if you can.Does Verizon charge updates against our monthly data allotment?
No sir.Does this update have the new Google Assistant in it?
I have mine up and running. It did take a while. I do noticing quite a few changes from beta 1. It's going to be quite different for Marshmallow users. I am really liking it.Don't think anybody has it installed yet. Mine's at 61% and counting.
No it does not. It will be a separate update from Google via Google Play Services update.Mine's still working. Did it include Google Assistant?
Is everyone going to just stick with the upgrade once it's done or a do a full wipe/clean install?
No Google Assistant. We're waiting on Google for that. They're doing their usual let's roll this out as slow as possible. They have to change it server side.Mine's still working. Did it include Google Assistant?
There's no real reason to wipe. If you have any issues, sure that's a good idea. However, I find that I never have the need.Is everyone going to just stick with the upgrade once it's done or a do a full wipe/clean install?
