1. erwaso's Avatar
    Does the GS7 have a burst shot mode and if so, hows it working? Clear or blurred for action shots?
    03-11-2016 01:27 PM
  2. dpham00's Avatar
    Yes it can do 100 bursts at a time (s6 did 30).it is better than the s6, but still can be blurry
    erwaso likes this.
    03-11-2016 01:34 PM
  3. Popersg's Avatar
    When you create an animated Gif from the burst shots via the Gallery app, can you animate it forward in time rather than default backward in time? Eg. if my burst shots are 1,2,3...N, the default animated Gif is N...3,2,1. This is a weird design...
    I can't find a way to reverse the sequencing.
    03-14-2016 02:36 AM
  4. lostsoul2's Avatar
    can you do animated gifs with videos you made too or only burst shots?
    03-14-2016 12:22 PM
  5. Popersg's Avatar
    What I know so far is you can create animated gif in the "Animated Gif" mode or you can take burst shots, edit them and then choose "Animate". However, the latter method will produce a backward sequence animation... the camera s/w developer must be dozing off when developing the codes.
    03-14-2016 12:33 PM
  6. Alanhd's Avatar
    I cannot find a burst mode on my S7 edge only animated gif, what am I missing.
    Edit.
    I'm an *****, you just press and hold under normal. I tried that but I was in pro mode and it doesn't seam to work in that mode.
    03-14-2016 01:37 PM
  7. mistus's Avatar
    can you activate hdr and burst more at the same time?
    03-14-2016 04:05 PM
  8. erwaso's Avatar
    Good question! Can you?
    03-17-2016 01:51 PM
  1. Unwanted Camera Burst Captures
    By isabel95 in forum Samsung Galaxy Note 4
    Last Post: 05-22-2016, 12:21 PM
  2. Quick night shot comparison. S6 Edge vs S7 Edge
    By sux2bu in forum Samsung Galaxy S7 edge
    Last Post: 03-15-2016, 07:43 PM
  3. Panorama shots?
    By sata in forum LG G4
    Last Post: 03-10-2016, 06:41 AM
  4. How can I share a screen shot in a group text?
    Last Post: 03-04-2016, 02:42 PM
  5. Replies: 0
    Last Post: 02-29-2016, 06:46 PM
