1. skhalid93's Avatar
    Hey guys, newbie that switched from iOS to android here. I want to transfer my music (or any file) from iTunes / Mac to my S7 Edge (Mac, OS X El Capitan 10.11.3).
    - Android File Transfer / Kies / Smart Switch are not working
    - Developer mode is enabled.
    - USB Debugging is enabled.
    - Phone & Mac have been restarted numerous times.
    - Changed multiple micro-USB cords.
    I can't find what the issue is, and I've been googling ever since I woke up this morning. If anyone can help me, thanks!
    - To admins : I really didn't know where to post this, so if this is in the wrong forum section, I'm sorry.
    03-11-2016 05:41 PM
  2. KimJongOMG's Avatar
    The easiest way I've found is to use Google Play Music.
    Here's a how-to. Also includes the MTP method so you could check and see if you're missing anything,
    Transfer iTunes library to Android | Direct or upload to Google Play - How-To - PC Advisor
    03-11-2016 05:55 PM
  3. scorpiodsu's Avatar
    I loved all my music to Google music to avoid this in the future. Whether I'm on iOS or Android, I always have access to my music.
    If you're going to to stick with iTunes the best approach I've used before moving to Google music is iSyncr. Download the app, install on your computer, hook the phone up and sync the playlists. Always worked well for me. Try it out. Link below.
    https://play.google.com/store/apps/d...s.Sync.Android
    03-11-2016 06:15 PM
  1. Galaxy S7 Facebook won't sync to contacts
    By AC Question in forum Samsung Galaxy S7
    Last Post: 03-16-2017, 01:32 PM
  2. How do I get my free VR gear for buying the verizon samsung s7 edge
    By AC Question in forum Samsung Galaxy S7 edge
    Last Post: 03-12-2016, 02:20 AM
  3. Replies: 3
    Last Post: 03-11-2016, 08:21 PM
  4. Where do my downloaded photos go on the new S7?
    Last Post: 03-11-2016, 08:02 PM
  5. Replies: 1
    Last Post: 03-11-2016, 07:53 PM
