1. scotchipman's Avatar
    Does the S7 edge come with anything pre-installed? If not what are some of the best to use?
    Mohsen Adel likes this.
    03-11-2016 06:32 PM
  2. Bryant Laney's Avatar
    You shouldn't need Antivirus on Android.
    bhatech likes this.
    03-11-2016 06:36 PM
  3. zipro's Avatar
    As long as you don't enable third-party app stores and install Chinese-made p0rn apps, you don't need antivirus software on Android any more than on an iPhone.
    03-11-2016 11:40 PM
  4. GeodudeFFP's Avatar
    Bitdefender Mobile Security.
    03-12-2016 01:41 AM
  5. mavrrick's Avatar
    Lookout is already on the phone.
    03-12-2016 02:05 AM
  6. GeodudeFFP's Avatar
    Disable it and use Bitdefender if you want a better, less resource-hungry solution.
    03-12-2016 03:08 AM
  7. sangs's Avatar
    Not on the Verizon phone - and I couldn't have been happier about. I hate that goddamn app.
    03-12-2016 06:12 AM
  8. scotchipman's Avatar
    I do visit risky sites sometimes but don't enable third-party app's. With all of the financial stuff on phones these days I want to be safe. Will look into Bitedefender unless it is really not going to help.
    03-12-2016 03:36 PM
  1. Replies: 1
    Last Post: 03-25-2016, 04:50 PM
  2. were i can find the stockrom for my samsung galaxy note?
    Last Post: 03-11-2016, 11:11 PM
  3. Replies: 0
    Last Post: 03-11-2016, 11:10 PM
  4. Replies: 0
    Last Post: 03-11-2016, 10:40 PM
  5. Galaxy Tab2 10.1 AT&T won't surf net after dis one room
    Last Post: 03-11-2016, 10:35 PM
