08-07-2016 05:19 PM
33 12
tools
  1. rickychonguy's Avatar
    One reason I switched to find my mobile, that I found out recently, is even if you have location turned off on the phone, if you hit locate device on find my mobile, it'll switch the phone location on and determine it's location for you. You also have the option of locking Samsung Pay.
    i tried this, but if my location its off..it wont find it.
    06-14-2016 10:14 AM
  2. soundchasr's Avatar
    Has anyone found a solution (or App) that will turn on GPS remotely so we can find a lost S7 (if I lose it)?
    Thanks!
    08-05-2016 01:41 PM
  3. kyle brown8's Avatar
    I'm not able to get this to work either? I'm signed in to my Samsung acount and on the website it shows my device, but it doesn't show as connected. The Help tutorial says to go to Main Menu>Setting>Security>Remote Controls to enable. I'm not finding that anywhere in the S7 menus. Any ideas?
    I found mine in the Google settings & try from another cell phone or home comouter it should work
    08-06-2016 02:58 PM
  4. soundchasr's Avatar
    Can you give more specifics? I thought Verizon had turned this feature off. I'm not sure how you got it to work....
    08-06-2016 06:33 PM
  5. chanchan05's Avatar
    I went to chat support on findmymobile.Samsung.com. AMAZINGLY they say that the S7 IS NOT SUPPORTED in findmymobile. Thanks Samsung. Is this your flagship phone?????????????
    It's in Settings>Lockscreen and Security.
    08-07-2016 08:11 AM
  6. soundchasr's Avatar
    Not on the S7.
    08-07-2016 12:34 PM
  7. chanchan05's Avatar
    Not on the S7.
    Yes on the S7. The only way it would have been removed is if your carrier disabled it. Which some are known to have done so.
    Here's video showing someone activating it on his S7
    08-07-2016 05:04 PM
  8. soundchasr's Avatar
    Verizon disabled. And of course offered no other solution. Wonder if there's a way to get it back if rooted.
    08-07-2016 05:19 PM
33 12
  1. A new pop up since the AT&T update to my Note 5.
    Last Post: 03-12-2016, 12:35 AM
  2. Replies: 1
    Last Post: 03-12-2016, 12:17 AM
  3. were i can find the stockrom for my samsung galaxy note?
    Last Post: 03-12-2016, 12:11 AM
  4. Replies: 0
    Last Post: 03-12-2016, 12:10 AM
  5. Why arent any videos on my phone working?
    Last Post: 03-11-2016, 11:52 PM
