1. JohnMidnight's Avatar
    I bought a PNY 128GB for the new phone off of Amazon (I would link the specific one, but 10 posts are needed for that)
    Worked great, till I get away from home and leave behind a microsd-SD card adapter, because the SOB hates the SG7E. IT works fine in my SG5, but no longer in the 7, ideas?
    My 5's 64 GB is now in the device and working fine. Not. Happy.
    03-11-2016 08:28 PM
  2. dpham00's Avatar
    I would try to format the csrd the and try again
    03-11-2016 08:40 PM
  3. KimJongOMG's Avatar
    I've had so many issues with non-Samsung SD cards on my other Samsung devices I just avoid them altogether now. My 128GB Samsung Pro+ is running like a champ right now thankfully.
    03-11-2016 08:43 PM
  4. JohnMidnight's Avatar
    I figured out I could do it on the G5, I formated the 128, then unmounted and removed card. Unmounted the 64 from the 7, installed the 128 and all good.
    KimJongOMG: My first PNY card >.> usually, strictly, buy Sandisk cards >.>
    Update: Neither Sandisk card or PNY card are readable on the Edge 7 when files are added via USB cable.
    Tried my Class 10 Sandisk, vs the Class 4. Class 10 works fine so far, not a single issue. the PNY is a "Class 10" but not a 11, 12 >.>
    03-11-2016 08:51 PM
  5. KimJongOMG's Avatar
    I love PNY cards but I've never used one in a Samsung. I've ALWAYS had issues with a SanDisk card in my Sammies which turned me off non-Samsung cards altogether.
    Where are you buying these cards? There are so many counterfeits out there these days it's disturbing.
    03-11-2016 10:26 PM
  6. zipro's Avatar
    Got a Samsung Pro+ and it works like a charm
    03-12-2016 12:24 AM
  7. JAG21979's Avatar
    Bought and installed a 64gb SanDisk and it works great! Absolutely no issues so far.
    03-12-2016 12:55 AM
  1. Replies: 1
    Last Post: 03-12-2016, 12:17 AM
  2. were i can find the stockrom for my samsung galaxy note?
    Last Post: 03-12-2016, 12:11 AM
  3. Replies: 0
    Last Post: 03-12-2016, 12:10 AM
  4. Why arent any videos on my phone working?
    Last Post: 03-11-2016, 11:52 PM
  5. Replies: 0
    Last Post: 03-11-2016, 11:42 PM
