Originally Posted by
Luis Miguel Batista i read the same. That a standard old UHS/U1 card is enough, that S7/S7edge isn't going to take advantage of higher max speeds...
What about know?
5 cent. anyone?
My understanding is that UHS-II is a different physical port and requires more pin connections than what is in the S7/S7e.
I'm actually not sure if any device supports the UHS-II standard (would need to do more research).
