1. Jason Fournier1's Avatar
    This morning my alarm didn't go off. I had a notification that said missed alarm. I am using the standard Clock app. I was still in do not disturb mode, but that never mattered before. The phone was on the charger and in always on display made so I don't think Doze could have been the cause. Any others see this problem?
    03-12-2016 06:07 AM
  2. andrew_ackley's Avatar
    Doubt it was doze. The alarm I think has a separate volume control. I always download the Google clock app and use that. It just has always seemed more reliable for me at least.
    03-12-2016 08:11 AM
  3. Monee_121's Avatar
    You have to check the settings on Do Not Disturb. There are 3 options - no exceptions, alarms only, and custom where you can allow certain calls or messages in addition to alarms. By default the option is no exceptions.
    Posted via AC App from my Galaxy S7 Edge
    03-12-2016 08:31 AM
  4. dpham00's Avatar
    What he said. Make sure to allow the alarm exception option in dnd
    03-12-2016 09:10 AM
  5. Jason Fournier1's Avatar
    Thanks yes the problem was the do not disturb setting.
    03-17-2016 01:49 PM
  1. Problem with Samsung Galaxy S6 Active after AT&T software update
    By kattrinakitten in forum Android 5.0 Lollipop
    Last Post: 03-13-2016, 07:49 AM
  2. Replies: 2
    Last Post: 03-12-2016, 12:33 PM
  3. Replies: 2
    Last Post: 03-12-2016, 08:20 AM
  4. rooting problem with galaxy grand neo plus with KingoRoot
    Last Post: 03-12-2016, 05:57 AM
  5. Replies: 0
    Last Post: 03-12-2016, 03:22 AM
