02-25-2017 11:54 PM
37 12
tools
  1. bigslam123's Avatar
    Download macrodroid and just create a macro. That's what I did.
    03-30-2016 08:36 PM
  2. RedSkyRoad's Avatar
    Thanks for this app suggestion. What did you use as a trigger for Do Not Disturb mode?
    04-01-2016 08:07 PM
  3. beardybrewer's Avatar
    OK here's what I came up with to disable the LED light. I set it up to turn off when the phone is on the wireless charger.
    Thanks for the tip on the plug-in. I bought Tasker but never took the time to set it up. You're instructions were perfect and hopefully that means no more blinking blue lights when I sleep.
    Cheers!
    10-07-2016 04:25 AM
  4. traceytaylor's Avatar
    Prolly flip the phone over is the best bet.
    Wow. Not a solution, and "prolly" is just...disconcerting.
    11-07-2016 09:23 AM
  5. Rick Dvorak's Avatar
    Thanks for the Tasker info!!
    01-31-2017 11:57 AM
  6. pappcam's Avatar
    Yes. This is what I did.
    I have it setup to disable the LED if it's charging and it's between 10pm and 7am. This works perfectly and it's much easier to setup than Tasker. It's also free as it only takes 2 macros to do this and the free version allows up to 5 macros.
    01-31-2017 12:14 PM
  7. trucksmoveamerica#AC's Avatar
    Prerequisites:
    Tasker ($2.99):
    https://play.google.com/store/apps/d...ndroid.taskerm
    Samsung LED Controller Plugin (Free):
    https://play.google.com/store/apps/d...3ledcontroller
    Profile > + > State > Power > Power
    Source: Any, AC, USB, Wireless, Other (I chose wireless)
    New Task > + > Name it (Optional; I named the first one LEDoff)
    + > Plugin> Galaxy S3 LED Controller
    Configuration (Select the Pencil)
    Everything should be off
    Check mark
    Backout to Profiles tab
    Long press LED Controller
    Add Exit Task
    New Task +
    Name it (Optional; I named the second one LEDon)
    Everything should be on except blocking mode and power saving mode
    Check mark
    The Samsung led plugin link not working. Do you have to be rooted for this to work?
    01-31-2017 03:33 PM
  8. pappcam's Avatar
    Use MacroDroid. Easier and cheaper (free)
    02-01-2017 10:20 AM
  9. trucksmoveamerica#AC's Avatar
    Downloaded it, I'm presently looking how to do it. There's no setting for while in charger, wireless charging, or do not disturb mode. I'll keep looking, but any suggestions let me know, I'm a ***** when it comes to this. LOL
    02-01-2017 12:47 PM
  10. pappcam's Avatar
    I used this exact YouTube guide.
    This is really made for disabling between certain hours while it's being charged independently of your Do Not Disturb settings.. If you want the LED disabled while it's not being charged then I'm not sure.
    02-01-2017 01:02 PM
  11. trucksmoveamerica#AC's Avatar
    Thanks. Figuring some of it out doing exactly that, YouTube. LOL
    02-01-2017 01:21 PM
  12. pizza_pablo's Avatar
    Settings - display - led notification. I turn it off at night as well.
    Thanks, for this!
    How silly, that this setting is not under the NOTIFICATION menu!
    02-25-2017 11:54 PM
37 12
  1. S7 - how to remove annoying ads
    Last Post: 01-22-2017, 05:28 PM
  2. Replies: 1
    Last Post: 03-12-2016, 07:28 AM
  3. Replies: 0
    Last Post: 03-12-2016, 07:00 AM
  4. Replies: 0
    Last Post: 03-12-2016, 06:52 AM
  5. Replies: 0
    Last Post: 03-12-2016, 06:50 AM
