02-26-2017 12:54 AM
37 12
tools
  1. badMojo69's Avatar
    I like to set up DND on all my phones and I can't find a way to disable the LED during this time. That blue LED is crazy annoying at night in a dark room. It's my first Samsung phone, so I'm a little lost.
    03-12-2016 08:35 AM
  2. ClintRo's Avatar
    I need this too.... I would rather not use an app for it.
    03-12-2016 08:38 AM
  3. 20degrees's Avatar
    Prolly flip the phone over is the best bet.
    llfloyd79 and crazycrew like this.
    03-12-2016 08:40 AM
  4. bkeaver's Avatar
    I use tasker and setup a profile and it works for me. I have it set to activate between certain times and only when it's charging Any way to disable LED during Do not disturb?-uploadfromtaptalk1457791710065.jpg
    badMojo69 and dpham00 like this.
    03-12-2016 09:08 AM
  5. badMojo69's Avatar
    Maybe when I get a case for it, but then that kind of defeats the purpose of having the clock showing for me.
    Its very dim and not distracting, but the blue LED...ouch.
    03-12-2016 09:32 AM
  6. dpham00's Avatar
    I agree that Tasker is the way to go, if you want this.
    03-12-2016 09:51 AM
  7. pinkvikchick's Avatar
    I know HUH!! I was so happy about the always on display thingie, used it last night (with the DND on) and the blasted blue light was on all night. Back to "My Alarm Clock" app. I googled this when I first got my Note 5, coming from iPhone/bb and it's been a complaint for a while.
    So that's my ONE complaint for this phone LOL...minor....
    03-12-2016 09:58 AM
  8. alejovh1's Avatar
    Settings - display - led notification. I turn it off at night as well.
    03-12-2016 10:21 AM
  9. badMojo69's Avatar
    Yea I know that, but that was not the question. Well maybe it was. I guess I should have to said to "auto disable".
    03-12-2016 12:04 PM
  10. anon(238680)'s Avatar
    If you want the phone to display a clock at night, but want DND otherwise, can't you just place the phone on it's face as previously noted and turn on Edge clock display? I haven't messed with the Edge stuff that much, but remember seeing the clock display available.
    03-12-2016 01:57 PM
  11. albie999's Avatar
    Tried putting face down last night, but the LED is still so bright it lights the room up. I have turned off the LED notification until find a way of switching off at night
    03-12-2016 02:56 PM
  12. Wildo6882's Avatar
    I use tasker and setup a profile and it works for me. I have it set to activate between certain times and only when it's charging Click image for larger version.
    If you don't mind, I'm terrible with Tasker, but can you explain a little more what you did to get it to work?
    03-12-2016 03:11 PM
  13. yomny Martinez's Avatar
    This is horrible, using third party apps just to disable this while on DND is bad lol. These other apps have a million other options and LED colors that i'm just not interested in. Tasker seems to be a paid for app but im not that eager to get rid of the LED. Hopefully something oem comes along to allow this exception.
    Edit- I even tried to create a setting(activity) shortcut using Nova launcer to have a toggle for the LED indicator around the home screen but no luck.
    03-17-2016 03:32 PM
  14. Tarah Sorber's Avatar
    I agree I end up waking up at night because of the flashing light.
    03-17-2016 08:48 PM
  15. albie999's Avatar
    Can you give a little more info on how you have these setup please?
    03-23-2016 10:28 AM
  16. meyerweb#CB's Avatar
    Lightflow will let you disable the LED while the phone is in DND, I believe.
    03-23-2016 10:38 AM
  17. CNL418's Avatar
    I'm having this same problem. I just upgraded from the S5 and the LED was completely disabled during DND on that phone. This missing feature is disappointing to say the least.
    03-24-2016 01:03 AM
  18. ClintRo's Avatar
    I had to install lightwave LIGHT FLOW to set a sleep schedule.
    I used this thread: http://forums.androidcentral.com/sam...functions.html
    03-24-2016 08:20 AM
  19. meyerweb#CB's Avatar
    I had to install lightwave to set a sleep schedule.
    Lightwave, or lightflow?
    03-24-2016 01:45 PM
  20. ClintRo's Avatar
    Sorry ... Light Flow
    03-24-2016 01:50 PM
  21. meyerweb#CB's Avatar
    Lightflow created other issues for me, but I've found a tasker plug in that works, for those who have managed to figure out tasker. The built-in Tasker control to turn the LED on and off doesn't work, but this plugin does:
    https://play.google.com/store/apps/d...3ledcontroller
    03-28-2016 11:06 PM
  22. wxman2003's Avatar
    What's just as bad is the blue LED light on the Samsung rapid charger. It's just as bright at night. Had to put a piece of black electrical tape over the LED on the charger.
    03-29-2016 02:39 AM
  23. JimA's Avatar
    For those of us who aren't familiar with tasker, can you give us a quick guide on running the plugin, or point us to a link? Thanks.
    albie999 likes this.
    03-29-2016 09:25 AM
  24. meyerweb#CB's Avatar
    Unfortunately, there's no such thing as a quick guide to Tasker. It's almost like learning how to program. It's complicated, but if you work at it suddenly it will start to make sense, and then it's a very powerful tool for automating all kinds of things.
    I'd take a look here: Tasker for Android
    and here: https://www.reddit.com/r/tasker/comm...ide_for_noobs/
    and maybe some of these links: https://www.google.com/webhp?sourcei...asker+tutorial
    It's not hard, it's just a steep learning curve.
    03-29-2016 01:04 PM
  25. JimA's Avatar
    OK here's what I came up with to disable the LED light. I set it up to turn off when the phone is on the wireless charger.
    Prerequisites:
    Tasker ($2.99):
    https://play.google.com/store/apps/d...ndroid.taskerm
    Samsung LED Controller Plugin (Free):
    Profile > + > State > Power > Power
    Source: Any, AC, USB, Wireless, Other (I chose wireless)
    New Task > + > Name it (Optional; I named the first one LEDoff)
    + > Plugin> Galaxy S3 LED Controller
    Configuration (Select the Pencil)
    Everything should be off
    Check mark
    Backout to Profiles tab
    Long press LED Controller
    Add Exit Task
    New Task +
    Name it (Optional; I named the second one LEDon)
    Everything should be on except blocking mode and power saving mode
    Check mark
    beardybrewer likes this.
    03-30-2016 05:55 PM
37 12
  1. S7 - how to remove annoying ads
    Last Post: 01-22-2017, 06:28 PM
  2. Replies: 1
    Last Post: 03-12-2016, 08:28 AM
  3. Replies: 0
    Last Post: 03-12-2016, 08:00 AM
  4. Replies: 0
    Last Post: 03-12-2016, 07:52 AM
  5. Replies: 0
    Last Post: 03-12-2016, 07:50 AM
