1. Monee_121's Avatar
    Hola! So obviously coming from S6 Edge there was no external storage. During the switch process it didn't
    give me an option of where to store my music tracks. Right now they are on the device, and I would like them moved to the SD. How do I do this? I have completely forgotten how I did it on my S5. Thanks!
    Posted via AC App from my Galaxy S7 Edge
    03-12-2016 09:04 AM
  2. kellyjdrummer's Avatar
    Does that model have the "My Files" app? Drag and drop or "Move" in the My Files app.
    03-12-2016 09:16 AM
  3. Monee_121's Avatar
    I was originally looking in wrong folder in My Files, I found them all and dragged and dropped. Thank you!
    03-12-2016 09:21 AM
  4. dpham00's Avatar
    Glad that it worked for you
    03-12-2016 09:47 AM
  5. kellyjdrummer's Avatar
    I'm glad to help.
    03-12-2016 10:53 AM
  6. DLKS's Avatar
    If you don't like the MyFiles stock app you can also use ESFileExplorer. It will ask for your permission to write to the SD card and you can do many more actions.
    03-12-2016 11:30 AM
  7. Monee_121's Avatar
    I'll be sure to check this out thanks!
    03-12-2016 11:58 AM
  1. Any way to disable LED during Do not disturb?
    By badMojo69 in forum Samsung Galaxy S7 edge
    Last Post: 02-26-2017, 12:54 AM
  2. Why i cant turn my wi-fi on?
    Last Post: 03-12-2016, 08:59 AM
  3. OneDrive: How do I get it to ignore movies, etc?
    By oceanclub in forum Ask a Question
    Last Post: 03-12-2016, 08:56 AM
  4. where are my straight talk minutes on my Samsung galaxy s4
    Last Post: 03-12-2016, 08:53 AM
  5. Replies: 0
    Last Post: 03-12-2016, 08:43 AM
