Every new font I try and download and then apply says not supported.... Anyone got a fix for this? Anyone? Bueller? Bueller?
I downloaded a font as well as a cool theme from Samsung and I had no problem.
Go settings, then display, then font.
Open Galaxy Apps, search for a font, install, then go to the fonts section in settings. Fonts downloaded of the Galaxy Apps shpw up there.I've gone to settings, display, font ....NOT ONE OF THEM WORK! Love the phone, hate that I'm limited more than any and ALL the Samsung series I've owned. Getting frustrated! If you respond please be detailed on where and how you got these fonts to work? THANKS
Found a work around for this.
Download ifont off the Playstore.
Then, I downloaded a zip of the roboto font. Extracted it in a file manager, and it gave me the option to open in ifont. From there you can apply the font. The app itself has fonts that work with the phone now, I think.
Anyways here's the link if you wanna try it yourself :
material.google.com/resources/roboto-noto-fonts.html
This method might have worked in the beginning but it doesn't now. Phone wants you to disable or uninstall foundation. As for buying the fonts? The Samsung store barely has anything. Unless I'm looking in the wrong place for them but I only seen a few.
